Did I crossover to the dark side? (Square port porn inside)
Old 10-21-2017, 05:49 PM
  #141
blk00ss's Avatar
Originally Posted by Jtm2085
I'm jealous, that shifter set up is looking good!
Thanks bro. I like it better than dicking with the 6 speed leather all the time.
Old 10-21-2017, 05:58 PM
  #142
blk00ss's Avatar
Little more progress. Got the oil lines finalized(I hope lol). Both headers on for good. I don’t think I’m going to be able to run my Kooks y-pipe and 4” dump. So it might be for sale soon. Also got a hole in the firewall right behind where the intake will be, and a grommet installed. That’s where I’m going to run the Holley harness through.
Old 10-22-2017, 09:53 AM
  #143
sillysspeed's Avatar
Woah how'd I miss this thread!?? Gonna be a beast!
Old 10-22-2017, 10:20 AM
  #144
blk00ss's Avatar
Not a very hopping place anymore lol
Old 10-22-2017, 05:46 PM
  #145
big hammer's Avatar
Only the coolest of the cool are still here.
Old 10-22-2017, 10:40 PM
  #146
Received 3,111 Likes on 2,426 Posts
Well. That makes me feel a LOT better! lol
Old 10-23-2017, 06:26 PM
  #147
Zmg00camaross's Avatar
Make LS1TECH great again! With this thread lol
Old 10-25-2017, 12:42 AM
  #148
blk00ss's Avatar
Little more progress. Made some mounts for the IAT sensor and the MAP sensor. Got the Holley mocked up and mostly wired up. I’ve got to wire into the weird *** sensors that my throttle body uses. Both earlier model GM TPS and IAC. I’ve got to run a 0 gauge from the engine block to the battery. Need to order a alternator kit since this car didn’t come with one. Still need to do the radiator and fan. Still got to buy some fuel line to run from the y block to the rails the. To the regulator. Anyways, here’s some pics.
Holley mounted
IAT mount. You can see the old TPI IAC sensor on the side of the TB
Map sensor bracket. I’ll run a 1/4” black nylon tube from the push lock fitting on the throttle body to the map sensor.
Old 10-25-2017, 07:19 AM
  #149
Is that a rubber gromet holding the IAT?
Old 10-25-2017, 09:47 AM
  #150
blk00ss's Avatar
Yes. The same one that comes from the factory.
Old 10-25-2017, 09:50 AM
  #151
Patron's Avatar
Keep it up! Give a few of these Fords hell.
Old 11-03-2017, 11:01 PM
  #152
blk00ss's Avatar
Soon
Old 11-04-2017, 05:48 AM
  #153
Tuskyz28's Avatar
Let's get track numbers!!
Old 11-04-2017, 08:26 AM
  #154
Jtm2085's Avatar
You think it will will go 6.0’s with the new set up?
Old 11-04-2017, 11:14 AM
  #155
blk00ss's Avatar
Probably won’t get any track times this year because every place will be closed. But she WILL be doing street things soon
If I can get a damn 5.90 I’ll be excastic
Old 11-05-2017, 12:55 AM
  #156
blk00ss's Avatar
Fuel lines done. I like the way they turned out.
Old 11-05-2017, 08:24 AM
  #157
Tuskyz28's Avatar
How much does the car weigh now? I would expect a 5.60 in the 1/8!! Big cube with Big heads
If your car don't run a 5.8 to 5.9 something not right. Reason I say that it's a TFS 245 headed 416ci with the Mast Intake/cam motion solid roller running 5.8s on motor on the same compression as you.
Old 11-05-2017, 09:27 AM
  #158
blk00ss's Avatar
It won’t run that good on motor. Nitrous convertor and cam. Car should be around 3200 without me in it.
Old 11-05-2017, 11:32 AM
  #159
Patron's Avatar
5.80's or anything like that will not be tolerated. He's gonna do Way better than that.
Example: 408 race engine rev'ed to 8500 did a 5.70/5.80ish in a 3200 lbs Camaro. Thats around 800+ at the crank Black should be well past that in Hp and ET's. Once he gets it dialed in low 5's. Near 4 seconds hopefully. Low 8 close 7 in a 1/4 mile.
Old 11-05-2017, 11:55 AM
  #160
Patron's Avatar
Think BES stroked Nova's Camaro, with Ls7 heads.
Quick Reply: Did I crossover to the dark side? (Square port porn inside)
