Which Crankshaft Is Best for Me?
I see a bunch of different options on crankshafts, so I needed to know what everyone recommends.. I had another post but wasn't to specific so I started a new one..
I'm building a 427 with an F1R on it, I have the aster bracket to go along with it..
my main question is if a Manley crank will hold? I see some people having issues with the dragonslayer crank so I feel kinda eh about using that one..
Also, do I need a long snout crank?
Other than manley, whats another good option to atleast be safe at 1k hp?
PLEASE TELL ME I DONT NEED A BILLET CRANK
thanks
The S/C Pulley kit designed by Casey Wegner places the "blower" belt FIRST, the closest to the Timing Cover.
You may want to look at some of the GMPP crankshaft options.
I could supply a Crower Crankshaft ?
Lance
Told when I bought mine 2 years ago, as opposed
To forged offshore and finished here (compstar & dragonslayer).
I would/did chose a totally USA made Crank, Forged rather then Billet.
Above 1000 Crank HP Quality becomes evermore apparent.
If I were you, and it's not a full on race car, I'd run my Manley.
If it's a full on race car, I'd go billet.
Car will see more street time than anything. I'm very hard on it when I do drive it. I'm always under the impression that over building it will be best to avoid any issues. I was thinking of a billet crank but they are a bit pricy.
I will also see some track time here and there but nothing crazy. Will pretty much be a weekend warrior.
My goals are to have a streetable track car but also be able to beat it without worry of breaking the crank.
Not 100% sure if it's true but on Yellowbullet several people stated the the magnum is the same forging as the Dragonslayer but has more finish machine work done on it.
"Compstar Performance Crankshafts are designed by our engineers, and forged on proprietary dies, made to our specifications. They are rough machined from certified 4340 forgings to our tolerances, then finish machined in our facility."
What issues are you hearing about the Dragonslayer?
I would call Callies and see what they recommend, The fact that you're running a supercharger off of the snout will be a consideration. When I called them about my 408 roots bower build they recommended a Magnum if on a budget and assured me that it would be up to the task.
https://ls1tech.com/forums/forced-induction/1283671-callies-dragonslayer-cranks-not-strong-enough-supercharged-applications.html
https://ls1tech.com/forums/parts-cla...s-engines.html
I think what it meant was that the Dart blocks are the only ones the crank will drop right into since they're already machined for it.
