Swapping my current cam with milder one
USE you nose/eyes to MEASURE the exhaust gas particle content.
WHEN your eyes "burn" the HC are very high, the chance of a bad tune (not enough fuel).
WHEN your nose senses fuel the engine may be too Rich.
WHEN you have both the Spark Instant may be too great.
Please report ?
Lance
A stock cam with longtubes , no cats and dyno tune smells like exhaust.. that`s just the internal combustion engine
Those cams look to have less overlap, less overlap will ABSOLUTELY be noticeable, ESPECIALLY in the area he is concerned with. He doesn't like the idle, the smell, and mentioned the word driveability. When speaking about cams, overlap is the area you go to to change driveability.
Please report ?
Lance
With above Id be tuning before cam swapping. A lot of work and cost for a small variable.
Please report ?
Lance
But the high overlap could also cause excess HC/smell at idle
