Swapping my current cam with milder one
Old Aug 26, 2017 | 07:23 AM
the gaurd's Avatar
Default Swapping my current cam with milder one
Will It is time to swap my current cam ,,
my engine is 364ci with ported 821 heads + ls3 intake valves
milled 30"
6 l80e transmission
stock stall + stock 2.92 gears
current cam is (223/230 : 634/608 : 112+2)
suggested :
1-
223/235
624/624
116+4
2-
223/235
610/620
115+0
cmc-20
what do you think on those two cams ?
Old Aug 26, 2017 | 11:29 AM
KW Baraka's Avatar
What are your goals......besides a calmer idle?
Because that's pretty much all you're gonna see with the two cams you've listed.
Also.....what's your compression ratio?
KW
Old Aug 26, 2017 | 01:41 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Possibly less overlap to cruise with 2.92 gears would be my guess.
They will likely pull farther in the rpm range but make less peak tq.
Either one would be fine, but add some advance around 111 to pick up the bottom end some. Wont hurt how the cam idles or cruises. They are so close really youre splitting hairs over them.
Old Aug 26, 2017 | 01:55 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Cam #1 because of +4* Advance as suggested by ^^^^^^^^^^^^^^
Old Aug 26, 2017 | 02:31 PM
Blazingz28's Avatar
Brother just went from BTR Stage 4 ( 235/242 )
To the EPS "Stealth" cam - 222/226
Non-Sponsor Soliciting Policy
Old Aug 26, 2017 | 02:47 PM
spanks13's Avatar
Put a converter in it and swap the gears instead
Old Aug 26, 2017 | 10:45 PM
Dyno Junkie's Avatar
Totally agree
Old Aug 27, 2017 | 04:13 PM
the gaurd's Avatar
KW
my goals is better drivebility , Less nasty raw hydrocarbons (raw fuel smell) and Calmer lope.
Compression with the current cam 10.8:1 SCR , 8.45:1 DCR
Does those cams listed weaker than the current one?
the current cam put down 428 hp , 432 tq .. it is nasty tourqy cam but its a bit hard to drive.
Old Aug 27, 2017 | 04:16 PM
the gaurd's Avatar
I didn't like that cam,,pretty weak friend of mine installed it and regret it..
Old Aug 27, 2017 | 04:19 PM
the gaurd's Avatar
Good idea but I'm short on funds,,
Old Aug 27, 2017 | 04:22 PM
The first one then but if you dont have cats you wont get rid of the smell. less timing at idle will help the fuel smell but increase lope...but that cam wont lope much anyway.
Old Aug 28, 2017 | 11:43 PM
KW Baraka's Avatar
Originally Posted by the gaurd
my goals is better drivebility , Less nasty raw hydrocarbons (raw fuel smell) and Calmer lope.......
Your current cam has about 2.5 degrees of overlap.
I'm 99% certain that the issues you want to clear up are the result of a bad tune.
Yep!!
KW
Old Aug 29, 2017 | 09:00 AM
pantera_efi's Avatar
Default Cam Choice #1 116 L/C +3
Hi, I agree with the KW "tech" as the new/old cams are so close.
My first recommendation would have been the #1 with the 116L/C +3 (Split Overlap)
The change will improve the D/D of your car with better Top End.
Lance
Old Aug 31, 2017 | 09:12 AM
the gaurd's Avatar
Lance
So specs will be
223/235
624/624
116+3
Old Aug 31, 2017 | 11:46 AM
John B's Avatar
Moderator
Let me ask a dumb question....is your car properly tuned? Changing to one of the other cams wouldn't make a significant difference if it is properly tuned right now....I am a bit suspect by your comment about how "Less nasty raw hydrocarbons (raw fuel smell)" which leads me to believe that a large part of your drivability may be related to the tune rather than the size of the cam.
Old Aug 31, 2017 | 11:50 AM
Overlap will lead to that smell. like i said removing timing helps, but you'll still have it when you have nearly any amount of overlap. not having cats does it too.
Old Aug 31, 2017 | 01:44 PM
the gaurd's Avatar
look once I finished tunnig the the smell is acceptable but after a while let say 2 monthes or so it'll be back and I really hate the car for it .. Frien of mine has the 223/235 :: 116+4
on his ls3 engine + A6 and can barely smell the gas even though it catless
Old Aug 31, 2017 | 01:50 PM
the gaurd's Avatar
In my little experience.. positive overlap is the cause of raw hydrocarbons while negative overlap is pretty clean...
By the way l regret ordering the headers without cats. I think I putt 200 cell magnaflows
Old Aug 31, 2017 | 05:45 PM
Sounds like a tuning issue to me.
I daily drove a bigger cam in our last LS3.
The 416cid that replaced our LS3 is using a catless twin 3 1/2" system without any fuel smells.
Old Sep 1, 2017 | 11:42 PM
KW Baraka's Avatar
If you wanna spend the cash on a new cam, go for it.....your money.
My '95 Impala SS has a 6.5* overlap cam.....and it doesn't stink.
My '14 SS has an 18* overlap cam. Car shakes and shimmies like a bitch....but she don't stink.
Your car has only 2.5* overlap.....and she stinks. Trust me.....it ain't the cam's fault.
You have a tuning issue.....or you're running w/o cats.....or both. I'd bet a C-note on it.
KW
