Tool for servicing a single valve spring
I just recently finished a hybrid swap, brand new GMPP LS3 crate into a Nissan 240sx. After the first 30 mi break in period I decided to remove the headers to heat wrap them. This is when I noticed a small amount of oil (kinda wet) on the #6 exhaust port, compared to the more "chalky" carbon build up on the rest of the ports. Further inspection is showing oil to be seeping through from the valve stems so I suspect a valve stem seal
.Now my question is: will Tim's valve spring compressor tool work without having to remove the valve rocker arm pivot support? All of the write-up I've seen removes all of the rocker arms and the rocker arm pivot support. I'm trying to avoid all of that and just trying to service the #6 exhaust valve. I'm thinking of using the valve spring tool you can rent from the part store but research is telling me to stay away from that. Any input is much appreciated! Thanks
https://www.summitracing.com/parts/oes-25220/overview/
http://www.ebay.com/bhp/ls-valve-spring-compressor
Or...
http://www.ebay.com/itm/Proform-6760...-/232240266870
The slotted hole means it can be used in any head style ls engine.
