PTV clearance with 64cc heads and flat tops
Old Sep 11, 2017 | 04:30 PM
milesg's Avatar
Default PTV clearance with 64cc heads and flat tops
I have a 05 Gto with a twin turbo ls2. Just ordered -3.2cc flat tops pistons and new h beam rods. Would I run into any issues with valve clearance with a 64cc livernois heads and the tick stage 2 turbo cam 235/231 .635"/.605" LSA114+6 cam. Also with that high of a compression ratio be beneficial with boost? I will be measuring PTV but don't want to order of it will be too close. Thanks in advance!
Old Sep 12, 2017 | 07:07 AM
KCS's Avatar
KCS
Moderator
Doubtful. Judging by the valve relief volume, I'm guessing those are Wiseco pistons. The depth of the reliefs are pretty generous so you shouldn't have any issues.
