New LS build Cam Recommendation
Old Sep 13, 2017 | 11:26 PM
aps63's Avatar
Default New LS build Cam Recommendation
Ok guy's, this is my first LS build and my first engine build in many years.
Trying to choose a cam , I contacted Comp Cams and this is what they suggested for me.
I told them it would be mainly a street car with the occasional auto or road course. I also said I was looking for around 450 hp. Maybe it's just me but does seem like a very aggressive cam for my purposes? Please let me know what you think.
lQ9 10.0:1 compression
L92 heads
Single plane manifold & carb
Stock rockers 1.7:1
Stock bottom end except for upgraded rods.
Long tube headers
3:73 Rear
Auto trans
Old Sep 13, 2017 | 11:40 PM
450HP to the wheels or flywheel?
Call Cam Motion. They are really on the ball with LS cams. It's all they do, and they are GOOD!
Old Sep 14, 2017 | 12:55 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Cut that on a 111+3 gain a little more ptv
We can get you that cam. its actually a fairly standard med sized rec port cam...like some stg3 stuff.
You want less we have the high lift asa cam its a 226/236 .600/.600 110+3 its a bit more tame but still rowdy at idle. great for a single plane.
It runs $385.
Old Sep 14, 2017 | 08:07 AM
aps63's Avatar
450hp to the flywheel.
Old Sep 14, 2017 | 09:58 AM
Our high lift hot cam does 385+ rwhp which is over 450 crank
Sounds like this
Old Sep 14, 2017 | 11:56 AM
aps63's Avatar
Thanks for the recommendations guy's, but I'm asking about this one.
Old Sep 14, 2017 | 12:07 PM
spanks13's Avatar
The recommended cam from Comp will make significantly more than 450 horsepower at the flywheel.
What stall torque converter?
Why limit yourself so much in power? The single plane isn't really the way to go unless you're planning to rev the thing out and make use of the top end. 450 hp out of the 6.0 would likely be doable (or very close) with the stock cam, heads, headers, and the intake you have - but the single plane will be down on power until the last 1000 rpm or so.
A dual plane intake with a mild cam, something like 218/224 on 110-112 would be much better suited to your power goals and would have way more midrange torque for things like autocross and cruising around the street.
Old Sep 14, 2017 | 12:59 PM
aps63's Avatar
Thanks for the reply, I'm not really trying to limit the HP but just want it to still be streetable.
I haven't chosen a converter yet, thought I would match it to the cam.
Thanks for the advice on the intake.
What kind of power do you think the Comp Cam would make?
Thanks again.
Old Sep 14, 2017 | 01:04 PM
That 231 239 would lose significant bottom end but have higher peak hp. id say 500 crank.
Old Sep 14, 2017 | 02:30 PM
imma_stocker's Avatar
That cam should have a lopey idle but still idle solid. Looks like it'll have a very fun mid-range torque curve. Be sure to touch base with reputable converter company that offers at least 1 re-stall if it doesn't come out as expected.
Old Sep 14, 2017 | 02:36 PM
Patron's Avatar
Even with a better cam your compression is still on the low side. 1 point of compression would fatten up your Hp/Tq curve all around. That's if you don't mind milling and checking PTV clearances depending on cam specs.
Sounds about right
https://www.google.com/amp/www.hotro...der-heads/amp/
Read this article a few times before and didn't pay attention to the 3.19 CSA.
Old Sep 14, 2017 | 02:38 PM
That comp cam with rec port heads wouldn't allow milling im pretty sure.
Old Sep 14, 2017 | 02:42 PM
The title of this thread implies you are looking for cam recommendations. That is what many here are doing. Comp Cams is not exactly A-list around here, as they don't specialize in LS engines, and don't have the close customer service some of the smaller more specialized grinders do. But do what you want. It's your project.
Old Sep 14, 2017 | 02:50 PM
aps63's Avatar
I wasn't trying to **** people off, just looking for some feedback on the grind Comp was offering me. So thanks for the info on Comp Cams, I didn't know that.
A lot of great info so far, thanks.
Old Sep 14, 2017 | 02:54 PM
No one pissed off. Just getting facts straight.
Old Sep 14, 2017 | 03:05 PM
aps63's Avatar
Cool, just trying to learn from you guy's.
Thanks again.
Old Sep 14, 2017 | 11:31 PM
KW Baraka's Avatar
Originally Posted by Patron
Even with a better cam your compression is still on the low side.......
Agreed.
IMO....you can get to 450 flywheel HP with a cam in the 220*/230* duration range.....and it would be FAR more optimal for your low compression engine.
But that 231*/239* cam? Way to much duration and overlap for that compression ratio.....no low RPM torque or drivability at all.....
Jus' sayin'.....
KW
Old Sep 19, 2017 | 11:32 PM
aps63's Avatar
Originally Posted by KW Baraka
Agreed.
Jus' sayin'.....
KW
Thanks KW, that's what I thought too.
Thanks again.
Old Sep 20, 2017 | 12:33 AM
big hammer's Avatar
Www.CallCamMotion.com
Old Sep 20, 2017 | 08:07 AM
Darth_V8r's Avatar
Moderator
Agreed.
Jus' sayin'.....
KW
Not trying to start a cathedral rectangle war, BUT......
That grind would be better suited for a 243 head off a LS6. The L92 is a great head and makes sense on a 6.0, but you will need two things done to really optimize:
1. The L92 is a very intake biased head. You tend to need more exhaust duration vs intake duration as compared to a cathedral head. In your case, that would mean likely keeping your exhaust in the high 230's and reducing intake to high 220's. A 227/239 - 113 would match up a lot better with the L92 heads and have less PTV concerns, if any.
2. Compression is your friend. That 70cc head would do you better at 64cc. That's a lot of milling, so you would have to worry about PTV. Or you could have them weld filled. Or you could swap to Pistons with better CR like flat topped or even domed. Which also effects PTV. Probably best to mill and then fly cut the Pistons.
Anyway, there's my $0.02
