LS3 deck height
Old Sep 20, 2017 | 10:50 AM
Ernie W's Avatar
Default LS3 deck height
I have a 2010 LS3 block with 60k miles. It is at the machine shop right now. I was talking to them about it and they suggest it be decked square with the mains, it probably could use a fresh surface anyways. I was telling them I couldn't go too far with it due to my pistons being at 0 deck at 9.240" according to wiseco specs. It hasn't been measured yet but I've read standard deck height varies from 9.235-9.245 most being 9.240".
So my question is will it hurt if my pistons are out of the hole .005 or so? They told me I don't want anything above deck, and if anything I'd want them down in the hole.
My pistons are Wiesco 4.070" -3.2cc valve reliefs and Callies compstar 6.125" rods, but I have not purchased rods yet. If its too bad, could they just mill tops of pistons? I don't think I'll run into anything major to come from it. They told me if they were out of the hole maybe run a 6.100" rod. That would put me down in the hole .010" or .015" depending on where everything is at.
So whats do you guys think? I did some research and they say its common for stock pistons to be above deck and some was talking about forged stuff saying sometimes .010 above deck.
Old Sep 20, 2017 | 11:35 AM
KCS's Avatar
KCS
Moderator
Above deck is pretty standard. You want your quench to be around .040", so .010" out and the stock .051" thick head gasket works out pretty well.
