Gmpp Cnc ls3 heads
Old Sep 21, 2017 | 06:49 PM
SPOOLIN Z28's Avatar
Default Gmpp Cnc ls3 heads
Any sponsors have any good deals going on for a set of gmpp Cnc ls3 heads? Looking to give my ls3 a little upgrade. I figure I can sell my stock ls3 heads and not be in a set of new heads for too much.
Old Sep 21, 2017 | 06:59 PM
You might do better with Texas Speed and Performance's LS3 port job. Their flow #'s beat GM's while keeping port volume less, which promotes better velocity.
Plus they will do YOUR heads for about $750/pr. plus any different springs or valves.
Old Sep 21, 2017 | 10:14 PM
big hammer's Avatar
They'll make some zoot but really need rpm to utilize them on a 6.2
Old Sep 21, 2017 | 10:23 PM
True, I just figured if he's doing heads, might as well get some that will be a bit better on the low/midrange than the GM heads.
IMO, a stock or near stock LS3 does not benefit from bigger ports. You might gain 10-15HP, but at what cost?
Now if a big cam is involved, then yeah, get some bigger ports to support the cam. Or to put it the other way around, if you get bigger ports, get a bigger cam to feed those ports!
Old Sep 21, 2017 | 11:25 PM
KW Baraka's Avatar
I would do a cam upgrade before I did a head upgrade. A lot more to be gained with more cam.
Point of fact; the three LS3 crate engines (430 HP, 495 HP, and 525 HP) are EXACTLY THE SAME.....except for different cams. And of course, they all have stock LS3 (OEM) heads.
http://www.chevrolet.com/performance/crate-engines/ls3
http://www.chevrolet.com/performance...ines/ls376-480
http://www.chevrolet.com/performance...ines/ls376-525
Just an example of what a well spec'ed, medium size cam can do with these engines.
Best of luck!
KW
Old Sep 21, 2017 | 11:36 PM
WORD! You have plenty of capacity in your present heads. A cam will wake up your engine WAAAY more than heads would, as KW says above
Old Sep 23, 2017 | 07:19 PM
99 Black Bird T/A's Avatar
One of those spiffy Radius Rod modified LS3 intake manifolds would likely help the LS3 stock heads pick up as much hp as the GMPP ported heads for a fraction of the cost.
Old Sep 23, 2017 | 09:09 PM
I would imagine the radius rod manifold and a mild cam would really kick it up a few notches.
We have flow tests, but has anyone dyno'd a stock ls3 with and without the radius rod mod? Or any cam, as long as the test compares the manifolds ONLY to make it unbiased.
Old Sep 26, 2017 | 04:32 PM
Engine has a Tsp 231/236 cam and Vic jr intake and 4150 tb
Old Dec 1, 2017 | 01:21 PM
Joeking1025's Avatar
I would like to see a dyno with the stock ls3 vs the cnc version on an ls3 with a decent cam to see the difference. I think there was a articles comparing the two but it was in a stock ls3 and the cnc were good for an additional 10 horsepower
Old Dec 2, 2017 | 02:06 AM
Papermachtech's Avatar
[QUOTE=KW Baraka Point of fact; the three LS3 crate engines (430 HP, 495 HP, and 525 HP) are [B]EXACTLY THE SAME[/B].....except for different cams. And of course, they all have stock LS3 (OEM) heads.
This is from the GM site for the 525 hp ls3;
The ASA camshaft is a hydraulic roller with .525-inch lift on both sides, along with 226 degrees duration on the intake side and 236 degrees on the exhaust side. And for durability, we complement the cam with higher-rate valve springs.
Old Dec 2, 2017 | 05:49 AM
KW Baraka's Avatar
I'll believe that when they list a part# for those 'new' springs. What I do know is that when that crate engine was first released (and until recently anyway) they came with the same springs as the OEM LS3.....
KW
Old Dec 2, 2017 | 05:53 AM
KW Baraka's Avatar
10 HP for a new set of heads costing $1000+.....versus up to 70hp for a well spec'ed cam and new springs. Don't need to be a rocket scientist......
KW
Old Dec 2, 2017 | 12:18 PM
Yeah, the old HP/$ ratio doesn't quite pan out on that one.... You can get much more for much less...
