Help with LQ9 Combo
Old Oct 14, 2017 | 04:47 PM
fmyth's Avatar
Default Help with LQ9 Combo
Last year I bought a sand rail with a Turnkey Lq9 engine in it. Turnkey advertised it as their 450hp package. It's a stock Lq9 short block with a GM Hot Cam, stock 862 heads and a LS1 intake and throttle body. It's in a sub 2,000lb car with a manual trans. It runs great, has awesome torque but runs out of steam at 6k rpms. I have the engine out to refresh the trans and would like to make some mods with the goal of increasing power in the upper RPMS.
I've read every thread on here I can find about LQ9 combos and have come to the conclusion that the 862 heads and LS1 intake/TB are likely holding it back in the upper RPMS. I have also read that I'll be limited by PTV clearance due to the stock flat top pistons. This is a low mile/hour engine and I want to keep the short block stock for this season (Halloween to Easter).
I am considering swapping the heads for a stock set of 243's and installing a Dorman LS2 intake and 92mm TB and keeping the hot cam. I believe this would lower my compression from an estimated 11.4 to 1 to 11 to 1. I think I can do it all for 2k.
What kind of gains should I expect?
Any other mods I could make that would get me another 40-50 hp and pull to 6,500 rpms for a 2k budget?
Old Oct 14, 2017 | 04:55 PM
For heads, find some 799's as they are identical to 243's, and came in all 5.3 truck engines since about 2007 until 2014 or 15.
Old Oct 15, 2017 | 10:59 AM
Crf450r420's Avatar
What is the end goal and what are you okay loosing? If you are going to stroke it to a 408 later you might want to just get LS3 heads now. Then you can probably leave your cam for now. The stock LS3 intake is cheap on Amazon and it is one of the best factory ones made. If you don't go big heads and use more cam then you'll loose more low end and street type manners, which I wouldn't think you'd care much about.
Old Oct 15, 2017 | 10:24 PM
fmyth's Avatar
I have done a little research on the LS3 head/intake swap but am concerned about PTV clearance with the LQ9 and GM Hot Cam.
Old Oct 16, 2017 | 07:00 AM
Tuskyz28's Avatar
You don't really have to start watching your PTV clearance to around 233-235 intake duration camshafts.....
Old Oct 16, 2017 | 02:10 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
What about +12-16 exhaust splits with <112* LSAs + ADV?
To broad of a statement with other variables.
Old Oct 16, 2017 | 02:38 PM
Tuskyz28's Avatar
Cam duration (lift plays less of a part) and piston-to-valve (P-V) clearance are inversely related. Each successive step up in duration decreases PTV.
Old Oct 16, 2017 | 04:52 PM
Crf450r420's Avatar
The intake is okay to about 230 degree duration on and stock LS3 with flat top pistons. Which GM Hot cam is it? Most of them were huge 117 LSA.
Old Oct 16, 2017 | 06:26 PM
fmyth's Avatar
The PO tells its this one:
LS Hot Cam
Duration @ .050" Lift( Deg): Intake: 219 / Exhaust: 228
Maximum Lift (in) W/ 1.7 Rocker: Intake: .525 / Exhaust: .525
Lobe Centerline ( deg): 112
I have no documentation on it so will need to check PTV clearance if I go with the LS3 heads.
Old Oct 16, 2017 | 07:23 PM
Crf450r420's Avatar
No cam is perfect, so it's best to check when getting close. I'm pretty sure you will find it over the .080" needed to be safe.
With stock heads and gaskets.
Old Oct 16, 2017 | 10:08 PM
KW Baraka's Avatar
There's only been two "GM Hot cams".
One for the Gen-II small block (LT1/4) and one for the LS.
Both have 112* LSA's.
Jus' sayin'.....
KW
Old Oct 16, 2017 | 11:49 PM
Tuskyz28's Avatar
Basically sane thing I said in my first post.
Old Oct 17, 2017 | 06:51 PM
Crf450r420's Avatar
The only GM Hot cam I ever used was a .550/.550 lift on a 117 LSA and that one wasn't really large enough for any of our builds, just used it when people insisted on a smaller cam that would idle very well.
Tuskyz28, I guess I'm not crazy.
Old Oct 17, 2017 | 10:04 PM
KW Baraka's Avatar
The only GM Hot cam I ever used was a .550/.550 lift on a 117 LSA.........
KW
Old Oct 17, 2017 | 11:07 PM
NO such thing as GM Hot Cam with .550 lift OR 117 LSA
Old Oct 17, 2017 | 11:14 PM
Crf450r420's Avatar
I have catalog here full of fresh BS just for you. 2012 GM Performance Catalog. I was wrong it's not 117LSA, it's 117.5LSA.
Old Oct 18, 2017 | 09:23 AM
That's an LS6 cam, NOT a Hot Cam. Read the print!
Old Oct 18, 2017 | 09:45 AM
Crf450r420's Avatar
You got me I don't know the cams that I never use and I call the 10 cams GM offers hot cams, not the first time I've had my own name for things and it's not the last. They don't do anything for me as only one or two of them are close to a hot level cam and none of them really fit our needs.
Old Oct 18, 2017 | 05:54 PM
KW Baraka's Avatar
Trivia note....both the LTx Hot Cam and the LSx Hot Cam have the same duration, same lift and same lobe separation angles.
Don't know why GM Performance Parts did that....but most Hot Cam users in the LT and LS world seem to be happy enough with the results.
Of course.....for 'hard core' power......the hot cams fall just a bit short.
KW
Old Oct 18, 2017 | 06:15 PM
They're happy because since it's called a Hot Cam, they bought the BS, put it in, loved the lope, and gained power. The fact that they're clueless as to what they could have had that would have done WAAAY better, is immaterial. GM made it, so it had to be good! lol
