Valve spring life
Moderator
I now understand how important it is to use a Lash Cap on BOTH the Inlet Valve and the Exhaust Valve.
When a Solid Roller Lifter is fitted there needs to be a way of adjusting the Valve Lash with the OEM style Rocker Arm, the best one to use in the engine.
What is stated : The Lash Cap is "sized" for correct lash, how clever !
I also found that the contact patch of rocker arm/valve stem is MUCH wider as the valve is lifted to .630" with Lash Caps fitted.
I have read threads here that state problems with rocker arm/valve stem wear.
Would this be the method that most here use to solve that problem ?
