Naturally Aspirated Cam
Old Nov 10, 2017 | 02:24 PM
flyin's Avatar
Default Naturally Aspirated Cam
Who is the go to, thee man to get a solid roller camshaft spec’ed for my combo?
I realize people will have their opinions, but I’d like to make power, not arguments LOL
TiA
Old Nov 10, 2017 | 02:47 PM
Tuskyz28's Avatar
Pat G in my book.
Old Nov 10, 2017 | 03:08 PM
Darth_V8r's Avatar
Moderator
PatG is great. So is Martin Smallwood. So is Kip Fabre at cam motion. If you are already doing solids, consider using cam motion LLSR.
Old Nov 10, 2017 | 03:27 PM
JakeFusion's Avatar
Super Hulk Smash
Ed Curtis and Geoff Skinner as well.
But I'd do the LLSR and then Kip, Pat, or Martin are all good choices as they are very familiar with the LLSR.
Old Nov 10, 2017 | 03:35 PM
flyin's Avatar
Ok, forgive me as it’s been a while since I’ve paid attention to things in LS1TECH.
Pat G always seemed conservative to me in his cam designs.
Kip is on my list to talk to
Martin did my current camshaft. Makes OK power at 720hp. However he has kind of disappeared lately. Hard to get a hold of
Ed Curtis is making great power right now with square port heads! Again very hard to communicate with
Forgot about Geoff, i will contact him
Also on my “to call list” is Bullet
Old Nov 10, 2017 | 04:09 PM
Pat G's cams might be conservative, but they WORK, sometimes better than ones seemingly "wilder". He KNOWS his cam events, and that is where the action is.
Old Nov 10, 2017 | 06:53 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Why pay more money for the same cam?
Talk to Kip or speedtigger for an llsr. I believe that cammotion has the best lobes and either of those 2 wont charge extra to give you what you want.
Old Nov 10, 2017 | 07:40 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Got my LLSR From Kip @ Cam Motion.
Excellent Product & Service!
Steven, AKA SpeedTigger is great also.
Old Nov 10, 2017 | 09:13 PM
Tony Mamo spec’ed my solid roller.
Old Nov 11, 2017 | 12:31 AM
Tuskyz28's Avatar
I have my reasons I like Pat G the most. He answers all questions HONESTLY. He asks the MOST questions about a build such as compression, intake, exhaust, car weight, heads, gearing, intended use of vehicle, etc.
I've seen him take him my buddie 402ci ws6 6 speed car to 10s with two different set of heads. 10.9s at 126.6 mph with CNC L92 heads then TFS 235 heads swap netted a 10.4 @ 132. He speced both cams for each set of heads. The car made 545 rwhp on the mustang dyno with the TFS heads.
The car weigh 3700 lbs with driver also so it's no tin can at all. He makes a stroker do what it suppose to do!! Its sad seeing 400 plus cube cars struggle to run 11s!
Old Nov 11, 2017 | 01:27 AM
03EBZ06's Avatar
Martin Smallwood . Once you talk to him, you will see he is the cam man.
Old Nov 11, 2017 | 10:51 AM
Darth_V8r's Avatar
Moderator
Yup. I seen Martin FIRST HAND spec a cam for a 346 that did 519 rwhp, and ran 10.8@129.
Old Nov 11, 2017 | 11:06 AM
flyin's Avatar
Like I said, Martin did my current cam. Hydraulic roller made 716hp on an engine dyno and it’s been 9.37@143.8 with a craptastic 60’ in a new chassis.
I’m looking to make enough power to run in the 8.8x range or better N/A.
Old Nov 11, 2017 | 12:11 PM
speedtigger's Avatar
Old School Heavy
TiA
It would be my privilege to help you with a solid roller. Just send me an email with all your details to Steven @ CamMotion.com. I will get with you on Monday.
Old Nov 11, 2017 | 12:59 PM
Darth_V8r's Avatar
Moderator
Really, for LLSR you should just call cam motion. Check out the 388 Steve canned to 630 RWHP...
Old Nov 11, 2017 | 01:08 PM
flyin's Avatar
Link??
Old Nov 11, 2017 | 01:55 PM
Darth_V8r's Avatar
Moderator
https://ls1tech.com/forums/dynamomet...hits-dyno.html
Here it is. It ran 10.4@136 on a track that was shut down to repave because the surface was greasy. There was an article on it in lsxmag too. Pretty badass car.
Old Nov 11, 2017 | 09:25 PM
1973 STEP A SIDE's Avatar
And Heavy !!
Old Nov 16, 2017 | 04:14 PM
David@Vengeance's Avatar
Hit up Ron@VengeanceRacing.net
Old Nov 16, 2017 | 05:37 PM
A.R. Shale Targa's Avatar
There's an old fart @ Bullet I've dealt with a few times who really knows his stuff....Used to work for Comp and was at Lunati when Harold Brookshire RIP(Ultradyne) was there.....Good quality AND service as well
I've run their old Flat Tappet Gen I solid/hydraulic stuff; a Low Lash BBC solid roller and a GEN III hydraulic roller......all have performed well !!!!!!
