Main tunnel issues on LS2
The local shop to me would always muriatic acid dip the threads to remove that black oxide coating crap
Use the ARP moly lube on the threads but EPL (extreme pressure lubricant) on the washer surfaces
This creates re-peatability without using up fastener stretches
Also; I always pull them up in three equal increases....EX; 50,60,70 etc.
Then lastly do the side bolts
