Compression ratio?
Old Dec 12, 2017 | 09:03 PM
Mdp11's Avatar
Default Compression ratio?
Any one on here run a zl 402 rotating assembly with ls6 heads? If so does anyone know there compression. Ratio..the 402 is rated at 11:1 compression depending ultimately on what heads and gaskets are being used
Old Dec 13, 2017 | 02:47 AM
A.R. Shale Targa's Avatar
And so what pistons are you using ??? Part number ?? CCs of valve reliefs ??
How far down in the hole are they @ TDC or are they sticking up and out ???
What gaskets are you using ??? What CCs are your combustion chambers ??
Where those heads CNC’d and/or milled ??? What compression ratio are you after ?? What is your use of this engine ??? What octane fuel do you have available or plan to use ???
It’s really a tad bit more involved than Just a 402 with LS6 heads
Old Dec 13, 2017 | 07:14 AM
MuhThugga's Avatar
http://www.csgnetwork.com/compcalc.html
That link is a calculator and has all of the parameters needed for finding the compression ratio. Plug away.
Old Dec 13, 2017 | 08:33 AM
Patron's Avatar
A.R. Shale Targa
X2 your on it like syrup on Belgian waffles.
By Brett Foote | 2026-06-04 05:00:17
