How much power does milling heads on 5.3 add?
I have a 08 lmg 5.3, it has 799 heads stock with flattop pistons. I'm doing a dod delete and ls2 cam, I was wondering while I had the heads off what kind of power would milling the heads to bump the compression up to 10.5 and how much to run stock gaskets. It's going in a rock crawler so I don't want to change cams I need low end torque and hp.
Has the engine been tuned or still running stock ECU? I'd plan on a tune... And you'll have to shop to find someone who does well with low RPM torque instead of red-line power,, Its hard to find a guy who can shift his process to a crawler engine vs a drag or race oriented point of view.. And knows how to get the power on just off idle..
https://www.briantooleyracing.com/tr...age-i-cam.html
