How long do valves last?
Old Dec 24, 2017 | 02:40 PM
cc-rider's Avatar
Default How long do valves last?
I’ve got set of 243 heads that came off a vehicle with 190k miles. I’m going to replace the springs, retainers, seals. But what about the valves? How long do valves last?
Old Dec 24, 2017 | 07:57 PM
While you have them off the engine, it would benefit you to have a valve job done. Very affordable, and your machinist will tell you if you have any issues as well. Most valves in these engines last many years, and hundreds of thousands of miles.
Old Dec 25, 2017 | 12:08 AM
KW Baraka's Avatar
Unless you have an extreme set-up that puts excessive stress on the valve-train or you have a poorly put-together valve-train, the valves usually last as long as the engine.
That said......get a valve job since the heads are off the engine.
KW
Old Dec 25, 2017 | 02:05 PM
Jimbo1367's Avatar
Send them to TEA for there stage II porting.
