Head gasket source
For more piston to valve, you can always advance or retard the cam. It will move the power band around a little, but at least it won't be as sensitive to timing.
Cole
LS1Tech Premium Sponsor
.030 is considered ideal quench. But you cannot just up and run a .030 gasket on an ls engine.
You will need a 4.085 gasket to work with 821 heads on any block be it 6.0 or 6.2.
We have a few diff varieties in stock compressed thickness of .051 or we can get cometic in .045 and .040. .040 is the thinnest i would recommend on a block where piston to deck clearance is unknown. we can get .060...but that's in the wrong direction for a street build.
They start at $70 a set and go up!
For more info, email me
Rpmspeedtech@gmail.com
