Small Cubic Inch LS3 NA Build
Old Dec 27, 2017 | 07:54 PM
topspeed1's Avatar
Default Small Cubic Inch LS3 NA Build
So unfortunately i changed directions and i wont be able to see if 500 whp is possible with a 5.3. But good news is that I started a Ls3 build.
My goals are to make as much power as possible out of a stock displacement 6.2. I dont want anything too crazy but drivability isnt as big of a concern as maximum power.
I already sourced a nice ls3 block which is sitting at the machine shop. I am just waiting on the JE +10cc dome pistons I ordered to come in.
I am looking for somewhere in the low to mid 13s on compression ratio. And I will be running e85
I am thinking about the trick flow 255 heads.
I plan to run a sheet metal intake or ITBs
I would like to close to 600rwhp
Thoughts or suggestions?
Old Dec 27, 2017 | 08:58 PM
600HP with the 6.2 will be a lot easier than 500HP out of a 5.3.
Old Jan 8, 2018 | 04:37 PM
topspeed1's Avatar
I cant decide between the trick flow 255s, the afr 260s or the prc 260s.
Any input on these heads would be helpful
Thanks
Old Feb 18, 2018 | 05:18 PM
Old Geezer's Avatar
https://ls1tech.com/forums/advanced-...e-posting.html
