Finally decided on ordering a set of Trickflow 255s. Valve spring question
Old Jan 1, 2018 | 01:23 PM
andy-lswon's Avatar
Default Finally decided on ordering a set of Trickflow 255s. Valve spring question
I finally ordered a set of the Trickflow 255s for my build and wondered of the Btr .660 valve spring kit would work in them. I had a set left over from doing a cam swap last year and they have a higher lift rating than both spring options that are offered with the Trickflows. I wondered which would be the better ones to use when everything is put together
Old Jan 1, 2018 | 04:51 PM
1973 STEP A SIDE's Avatar
I ordered mine from TEA and got the Pac .660 springs .
Old Jan 1, 2018 | 05:28 PM
KCS's Avatar
KCS
Moderator
The springs should work, but you may need different seals and locators for the bronze guides in the TFS heads.
Old Jan 1, 2018 | 06:35 PM
andy-lswon's Avatar
I'm ordering them from Tick but they come with the .650 springs. What's the difference in the Tea valves?
Old Jan 1, 2018 | 06:36 PM
andy-lswon's Avatar
they have powdered metal guides
Old Jan 1, 2018 | 06:37 PM
andy-lswon's Avatar
it looks like the ones from Tick already have the Tea valves in them
Old Jan 1, 2018 | 09:16 PM
Yes and I am sure the Pac .660 springs .
Old Jan 2, 2018 | 02:05 AM
KW Baraka's Avatar
What's 'wrong' with the springs that came with the Trick Flow Heads? Or....did you get bare heads?
KW
Old Jan 2, 2018 | 09:29 AM
andy-lswon's Avatar
KW
Nothing wrong with them. Just wondered which ones would be better to use since I already have a set of the Btr. 660s
Old Jan 2, 2018 | 09:40 PM
KW Baraka's Avatar
If you got the heads with the .650" springs.....run them. They're excellent springs for hydraulic cams. I like to keep valve lift at least .025" below the rated capacity of the springs (personal preference)....so if your valve lift is .625" or less, you are good to go.
I also consider springs a wear item, and I like to swap out springs every 15K to 30K....depending on application and how I use the car. So.....in a couple of years or so, you can swap in the BTR springs.
But for God's sake Andy, whatever you do......stop overthinking things.
The PAC springs on those TF heads, which I believe are the same as the springs on AFR's LS3 heads, are among the best you're gonna come across for your application.
Best of luck!
KW
