Spark plug heat range
Old Jan 4, 2018 | 08:26 PM
Black02SLPSS's Avatar
Default Spark plug heat range
Good evening everyone,
I am finishing up an LS3 build to swap into my 02 SS after the old LS1 decided to hydrolock cylinder 6 and commit suicide.
Long story short I have pieced together a cam only LS3, stock c/r, aftermarket throttle body and it will have full exhaust. The cam is an EPS 228/240 .630/.604 113 LSA.
So my question is will stock heat range plugs be perfectly fine or do i need to go to a lower heat range? Or would that be something to worry about if i changed the compression ratio?
Thanks
Old Jan 5, 2018 | 04:50 PM
Anyone?
Old Jan 5, 2018 | 08:39 PM
Dragls's Avatar
I would go with either NGK TR55 or TR6 iridiums.
On my 11.8 setup I'm running the NGK TR6 iridiums.
