419CI, AFR245 Cathedral, ITB Build
#61
The clamping pressure with the Monster clutch cover is a little greater plus the lack of auto adjuster is a good thing for pedal consistency i think.
#64
Been struggling for time, but got a few bits done, I spun the starter motor with no plugs in and got the oil pressure up, it’s showing 32psi, I will get it running this week!
#65
Anything yet?
#66
I have had these guys take one bank of the ITB’s away this week to make the filters..
http://itgairfilters.com/
#68
House extension??? Do you mean house addition? That with chew up a lot of money and time. Keep up the great work.
#69
I bought the ITB’s used, around $1500 at the time about 7years ago, Kinslers are silly money new I believe.
#75
Subscribed! I may have missed it, but when engine management are you using?
If it's a DBW GM PCM, are you using a servo to drive the mechanical linkage for the ITBs?
#76
Its a cable operation.
#79
Car moved under its own steam today, I reversed out of my unit and the brakes went to the floor! Next to useless stopping power, but I drove it around the yard just to get a feel for the new clutch plate, and I am pleased to say not a hint of judder and very smooth take up.
engine feels really sharp on the throttle pedal.
i dropped the wheels of and found a load of air in the front left caliper, why I don’t know? Something to do with being stood for so long???
Gonna be wary of that for a little while...
#80
If the brakes have not been touched...no way should there be air in there !
Mine has sat for months at a time, and never anything like that. Definitely keep an eye on that or check through the system
