CNC 243s on LS3
One thing I should point out though, before I started modding the car, there was a clear point that the car seemed to lose power to me. I don't have any proof of it but it just felt different after this one day. I was pulling onto the street and of course I gunned it, didn't think about traction control being on and when it started spinning the traction control pulled it down to the point of it almost quitting. I have no clue what it could have hurt but it never seemed right after that.
I've read a lot about porting the stock intake and I can't find any proof that it helps anything. Rick Crawford has said porting the factory intake doesn't help, but I know he does something different to them that does help.
How much do you think a fast 102 is worth over a stock LS3 intake or a Crawford modded one?
But I was sort of assuming a new cam was going to end up in his build anyway. My cathedral fast 102 works well with the stock LS2 rails. I'm not sure how those compare with the LS3 rails.
I appreciate all of the advice so far.
Also, I'm not afraid to turn it 6800-7000. It won't see that RPM very often so I think that will be fine.
BTW, how do you like that verter in the car? I was looking at their 278mm 3-3.2k version for my daily
I like the converter. It feels a little "clunky" for lack of better term, at times, but I like it because it feels like a stalled auto.
I originally had the 278mm 2800-3200 and hated it. It didn't even feel like it had a stall. Changed to the 278mm 3000-3200 and hated it also. Finally switched to the 245mm and all is well.
Circle D really worked with me until we got it the way I wanted it. I had an extra $100 or so in shipping costs but it was well worth it.
At minimum I would go with the 258mm. BUT, I love the feel of a stalled auto and have a high tolerance for that feel. My wife drives the G8 almost daily with the 245mm and hasn't complained.
My car cut stock 60' times with the 278mm (2.03). Now we know my car has something wrong and isn't dialed in because it only ran 8.38 @ 88mph, but it still should have cut a better short time than that. It wasn't any easier to do a burnout than with the stock converter. It wasn't very fast on take-off. It just basically didn't act like it had a stall imo.
I haven't taken it back to the track with the 245mm but I can light the tires up at will now and it's so much stronger taking off.
I seriously wouldn't even bother changing it if I was gonna go with a 278mm. If you got more than a .1 at the track I would be surprised.
Friend of mine had the same converter in an 88 monte carlo with a 6.0 and 4.10 gear and it wouldn't 60' either.
