Rod movement ????
Old Jan 22, 2018 | 09:55 AM
txh0tb0i972's Avatar
Default Rod movement ????
So i recently bought an ly6 with a couple thousand miles. Was told it was in running condition and ready to bolt in and go.
During my cleaning process and swapping over parts i decide to check the rods. (I've never messed with clearances or assembling a short block)
I notice the rods have some movement front to back. (timing cover to rear cover) but no movement side to side (side skirt to side skirt of the block)
Im just curious if this is normal or not, I'd hate to put it together and then pull it back out.
I know a rebuild will be mention but that was not my intentions as i was looking for a running motor and that's what i was informed of.
All input is greatly appreciated.
Old Jan 22, 2018 | 10:23 AM
KCS's Avatar
KCS
Moderator
That's normal, it's the rod side clearance. If you can stick a .010" feeler gauge between the rods, you're good to go.
Old Jan 22, 2018 | 10:24 AM
Awesome! Thanks for the clarification!
Definitely going to be checking that clearance later today.
