Building a NA LS2/3
Using a stock GM crank & rods, with the pistons chosen below (6.098 .945 Pin). Chose the +9cc pistons so I can keep the compression around stock LS2, though slightly higher without having to mill the heads. From what I understand Weisco uses a valve relief that will accommodate cathedral or square port heads.
Any one see potential any issues with the setup?
Block: GM LS2
Crank: GM 3.622 24X
Rods: GM 6.098 LS2/3 Floating or Scat I beams 2-ICR6100-944P
Pistons: Weisco K0044X1 (4.01 Bore, +9cc, Comp Height 1.311)
Oil Pump: WS6store Mahle Ported.
Heads: GM LS3
Head gasket: Stock LS3 Head Gasket (4.08 bore, .051 thickness)
Cam: TSP Stage 1 LS3 or similar cam kit with required springs.
Other Valve Train: GM crank sprocket / GM 1x cam gear, Katech C5R chain, Delco LS7 lifters. WS6store LS3 rockers with the upgrades.
Intake: Stock LS3, DBC after market throttle body.
Deck Clearance using 9.240: With stock rods and the listed compression height, it should 9.22, so sitting -.02 in the hole. Realize there’s some very slight variance here in block height, but trying to get an educated guess, seem most people use 9.240 as a standard measurement.
Calculated compression: 11.1:1, that’s with a 68CC head, maybe slightly higher with cleanup work to the head if I find a used set. Hoping to pick up a low mile set of heads or buy some new ones.
The AutoTec 4032 Alloy is what I would specify @ 4.005"-4.007" with NO COST increase for the "shelf" part change in bore size.
The RINGS are your specification with a 4" "file fit" cost as the lowest. (Steel NPR)
The Deck can also be custom ordered with no cost increase.
YOUR CONCERN should be about piston/pin/ring weight to be specified as LOWER than OEM Values.
This can save engine balance costs.
Wayne Brooks started J.E. pistons at the Racetec plant in HB, CA.
The same C/N/C equipment is used today, the ones JE's were machined with in the past.
I also sell Forged Rods with 8740 bolts.
Lance
Lance
