Head porting... SWIRL VEIN?
Your yellow Z? Heads, cam, compression, fuel? In 1500' that's killer mph with a 1.6...
all the testing I've done was with die, the ls7 port will go turbulent at high lift.
Once this happens the air is being sucked back up the short side. also the wing seems to help with flow numbers but once die is injected into the port the truth shows its self. on all high lift cams its better to have them removed here is a cathedal heads with the wing same thing you see here the ls7 is doing then a picture of how I port them for big cam cars or fi. did this to my own car and eveyone has gained trap speed its helped for me...an after testing a set of AI heads on my own car with the vein removed been doing this way since.
My BES ported LS7 heads have the wing taken out but the port floor has a heavy amount of taper to it. Don't know how it compares to a factory port. I assume is slows down the air by the cylinder wall and tries to speed it up towards the center of the bore but I don't know. I haven't run these but I've heard good things. They're ~285cc. You can see witness of where the wing was but it is pretty much entirely gone.
