High psi compression test L92?
Any ideas? carbon build up? I already seafoamed it and use only 93 octane and it runs like a beast, I can tell a difference just with the fuel change.
The VVT motor is locked by a pin for start cam advance positioning.
The Oil Pressure/PCM command changes cam timing AFTER the engine is in operation.
I have not done a compression test on my car, I would check for a GM specification ?
Lance
