Building a motor to support boost / 600 WHP
Anyhow in seriousness... Would I literally be good with a Reman LQ4 Short Block with good heads (maybe ported L92's?) and a good tune for 600 whp? If there's no advantage to going forged for my power goals then I probably won't...UNLESS you're recommending that I do however.
Calculating BSFC's and airflow and turbo efficiencies.....been there done that. My 2 bachelors degrees have let me "lrn2mth", have you graduated yet or are still in school?
You want to get technical, your original post is misleading and untruthful which is why I jumped in. It is missing information that is required in order to be useful.
This is missing required information to be useful. your post implies that at ANY BOOST, 15, 30, 50psi of boost will be fine. because it is ENTIRELY about the tune.
So even with 2 degrees you were so full of yourself that you didn't even check if the information you are providing will be useful, or in what context. Just goes to show how a degree really doesn't mean anything when it comes to an inflated know-it-all ego, does it.
The title of the thread and the 1st post tells me exactly what I need to know to answer the question....which shows how little you actually know about the turbo LS. Thanks for confirming.
'05+ for the beefier rods and widen the piston ring gap (which started this whole temperature debate). Managing A/F to control temps will still be a factor.
I'd shoot for 10PSI first to see where that gets you. You may be happy with that for the near term. Experiencing 500whp for the first time will probably be a thrill. Water/meth injection may not be necessary immediately and can control budget to get you up and running. You'll probably face other challenges like boost control, fueling, plumbing, heat management, exhaust, traction, etc. Later, when you've sorted the bugs and adjusted to the new-found power you can look into upping the boost and adding water/meth injection.
I'd shoot for 10PSI first to see where that gets you. You may be happy with that for the near term. Experiencing 500whp for the first time will probably be a thrill. Water/meth injection may not be necessary immediately and can control budget to get you up and running. Later, when you've adjusted to the power, you can look into upping the boost and adding water/meth injection.
Much easier to explain things in terms of EGT, piston material thermal expansion, temperature threshold. We can set a cap on EGT and be correct for all of the above variances; How we control that EGT is up to the owner/tuner. You say use more fuel... I say thats crazy waste of gas idiot (basically saying this to the car manufacturers, since they tune it richer than it needs to be) but like the guy below me says, its an advanced topic, too far in the future to go with this hypothetical build. Good point about looking at it from fuel only needs, however I still plan my water in advance thank you very much.
But don't take that to mean I don't still love you. I still love ya, buddy. But if we keep going I will start using math, and ur gonna start to hate this thread.
thing about gapping the rings is actually the most important part of all. I don't want to do it. Taking out the piston? No thanks. Part of the allure of this swap is the not-having-to-f-with-anything to get it to work. Thats why I feel water > ring gapping. Rings come and go- water stays.
Saying the oem manufacturers tune too rich to waste gas is assinine. Besides emissions, they have to go at least 100k miles for reliability.....which is your entire point about wanting reliability.....and the oems have that and run richer than you say they should. The entire reason youre saying to not run rich is absolutely opposite of the oems who care highly about reliability.....you just can't admit your arrogance and listen for a change....just like every thread you post in.
Yeah I can't figure out why the OEM isn't putting an extra unnecessary system on the cars which reduces economy and requires the owner to frequently re-fill or else have catastrophic engine failure. It eludes me completely why they don't do that. I think you missed where I was using sarcasm first, in order to not call you an idiot. But now you've done it to yourself.
Also you use a lot of dots after things as if you aren't really sure what you are saying....
All joking aside, literally the most ironic thing in this entire thread is that you're entire argument is based on reliability. The problem is that the OEM's agree with me, including 1 who is a member on here and regarded by many as the best tuner in the country and tunes for the OEM's. All this info is in his books, which is your bread and butter. Come jump on the bandwagon of reliability and high horsepower!
Most people have problems with the stock rings butting together cracking pistons, usually from a bad tune. A few ways to get around this:
1. Pop the pistons out and gap the rings.
2. Tune with super-safe timing and a mildly fat AFR.
3. Run water injection (does a decent job of cooling rings).
4. Run E85.
5. Run a high mileage engine that may have gained a few thousandths of gap (150k+).
I've been accidently been 42 PSI on a junkyard 5.3 with the stronger rods, and my recent tear down showed ZERO signs of detonation, bent rods, cracking pistons, butting rings, etc. This is also after over 2 years of 18-24 PSI street driving, 60+ dyno pulls, HUNDREDS of highway pulls. All on 93 octane with a splash of water/meth and a safe tune.
4. Run E85.
