Pushrod measuring confusion
ive bolted the heads on and used my Comp Cams pushrod checker, I’ve come out at 7.275 zero lash so going for Cam motion 7.350 5/8 pushrods, i then checked the checker with my large vernier and found at 6.800 it actually measures 6.822 tip to tip.
I phoned the manufacturer of the checker, the guy said been as I have the large vernier use that as the ultimate figure, I wasn’t convinced, I rang the cam manufacturer and he said depends who your pushrods are made by depends on on where they are measured from, but as it’s a hydraulic set up don’t sweat it, but the difference is a full different order part to me so I did “sweat”, i rang cam Motion and they said go with what the checker says as this is where the joints make contact, so yeah bit of a mess around for a simple job!
Some measure from the theoretical center of the sphere between each end, and others measure from the "flat" where the oil hole intersects the sphere.
Ever wonder why a pushrod checker has a flat on each end, this is why.
I have always used the "flat-to-flat" measurement of the pushrod checker.
I have also made my own "checker" by taking an old pushrod and cut a section of the tube out of the center and drilled/tapped threads and installed a 2" allen head set screw and two jam nuts. Then I can measure the "actual" length from "flat-to-flat" or "oil hole-to-oil hole" whatever you want to call it.
Cole
If you tell them what you're doing, they'll help you do the math. Give them all of the info on the parts you're using. I find that most every engine I build takes several different sizes to get "Dead on" between every rocker.
Just my opinion and two cents... Good luck.
