Lifter help please.
Old Apr 9, 2018 | 08:06 PM
mannyman84's Avatar
Default Lifter help please.
Is there a way to relieve the pressure on a lifter in the engine? I did .025 preload and the valves stay open because the lifter plunger is all the way up. Or should I just say the hell with preload?
Old Apr 9, 2018 | 08:07 PM
mannyman84's Avatar
Lunati linked lifters.
Old Apr 10, 2018 | 09:09 AM
KCS's Avatar
KCS
Moderator
Turn the crank over until the rocker reaches peak lift. The spring pressure should bleed the lifter down.
Old Apr 10, 2018 | 10:14 AM
mannyman84's Avatar
Ive cranked and cranked and nothing. They are probably stuck. Im probably going to have to pull the heads.
Old Apr 10, 2018 | 11:51 AM
ColeGTO's Avatar
Here's an idea:
Remove the oil gallery plug at the driver's side front of the block and turn the engine over by hand so the pressure in the oil galleries will be relieved and allow the lifters to bleed down.
May take a few revolutions to get all the lifters collapsed.
Old Apr 10, 2018 | 07:30 PM
mannyman84's Avatar
Originally Posted by ColeGTO
Here's an idea:
I'll go ahead and try that
Old Apr 10, 2018 | 10:55 PM
mannyman84's Avatar
Nothing is working. Heads are coming off. Thanks all
Old Apr 11, 2018 | 12:37 AM
ColeGTO's Avatar
That sucks. Good luck.
Old Apr 11, 2018 | 11:45 AM
pantera_efi's Avatar
Default Big Hammer = good tech
Hi 84, I HAVE FOUND "stuck" lifter plungers caused by manufactures coating their product for anti rust liquids that became DRYED OUT.
So I ask, did you fill the lifter with Oil BEFORE installation ?
I have had luck with a "love" tap using Big Hammer on the rocker push rod side.
I could feel it become loose/break free.
Lance
Old Apr 11, 2018 | 02:06 PM
mannyman84's Avatar
Hi lance, I haven't tried that just yet. Only problem is that on an fbody there isn't much room. I had an old set of lifters I replaced a while back from lunati and the only way I was able to release the pressure was with the vise. And even at that it was pretty tough. I'll try a bigger hammer and see how it goes. Don't want to break anything I don' have to.
Old Apr 11, 2018 | 03:42 PM
ColeGTO's Avatar
Lance
This would work on new lifters that have not had oil "pumped" into them, but not lifters that have been run.
When the body fills up with oil, there is a check valve disc that prevents the oil from escaping and allowing the filter to "collapse". The clearance between the lifter body and plunger is only .0002" or so.
I guess the only way to get the oil out is to remove the lifters and then the clip, pushrod cup, disc and plunger. Turn over the body and pour the oil out.
Unfortunately on an LS, the heads have to come off to do this. Sucks.
Old Apr 17, 2018 | 09:43 AM
RockinWs6's Avatar
Something is wrong with the lifters, either dirt sludge etc have blocked them. They should bleed off fairly quickly from just normal spring pressure. If you pull them out you will need to disassemble them and clean out what ever is blocking them. Will also have to flush the engine oil gallery to see what jammed them. I've seen this before, usually it's sludge but it could be other things. Usually happens after someone uses a cleaner product in the engine oil.
