Will these pistons work?
Old Apr 16, 2018 | 01:30 PM
YukonMatt's Avatar
Default Will these pistons work?
so I'm about to order pistons for my build I'm down to 3 choices. First off it a Gen iv 5.3 that I'm getting over board. I found these wiseco pistons that are dome +4cc 10.7:1 compression ratio but the pins are saying .945 wil those fit my wrist pin bushing or will they need honed out slightly. I see pin sizes for these from .943-.945 will any of them work?
Old Apr 16, 2018 | 02:06 PM
ColeGTO's Avatar
Probably going to have to hone the small end which isn't a big deal and should be checked anyhow. I honed my stock rods to fit the JE pistons I bought.
Old Apr 16, 2018 | 04:34 PM
YukonMatt's Avatar
Ok I didn't think that was going to be a big deal since the machinist is going to assemble the short block anyway. I do have another question about compression height. Factory flat top are 1.330 and these are 1.335. I'm not milling heads except for a very small resurface so I shouldn't have to worry about the piston hitting the head right?
Old Apr 16, 2018 | 06:24 PM
ColeGTO's Avatar
No, but you will want to measure how far above the deck surface the new pistons are. The head gasket thickness you choose is going to determine if the pistons are going to hit the head.
I recommend .040" clearance between the piston and head. You can run closer if you're absolutely certain of ALL your measurements/components. But I wouldn't go any closer than .030", I just don't think it's worth it in a typical street/strip type build.
Old Apr 17, 2018 | 01:12 PM
YukonMatt's Avatar
So one machine shop told me they wouldn't bore the aluminum block to 3.903 and the other shop told me they would do it but I'd have to buy forged rods they won't use the factory gen iv rods I have.
Old Apr 17, 2018 | 01:19 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
All Wiseco ls pistons work with .945 floating pin rods whether stock or aftermarket. You will not have to hone or machine them.
They can also work with pressed pin rods also you just do not use the pin locks.
Old Apr 17, 2018 | 01:29 PM
Id go to a different machine shop. The first one doesnt want your business the 2nd only wants your money. Find another one.
Old Apr 17, 2018 | 02:40 PM
ColeGTO's Avatar
The factory 5.3 iron or aluminum blocks can be safely bored to 3.908.
Buy your pistons and drop them with the block off at the shop that will do the bore/hone.
Take the rods and wrist pins to the other shop and have them at least checked for size/clearance. The factory wrist pins in my new SRP pistons were slightly larger and only had .0003" clearance in my stock Gen IV 6.2 rods. So I honed the stock rods to have .0010'-.0012" clearance.
Then take the crank/rods/pistons/wrist pins/locks/rings/bearings/etc. to what ever shop will balance them it for you.
