L96 Compression
. Stampede. ...what is a balance? Lol...no, all the dnr pistons I've used I never balanced the crank to...I put dnr 4.8 flat tops in a lm7 with no problems, put the ls2 dnr flat tops in my lq4, and l96, both also with no issues, so basically I raised the compression and ditched the dished pistons in those motors and yea I noticed a hellov difference in off the line power. ...what we're you planning on building? 4.8/5.3/6.0/6.2
In regards to rebalancing my setup, I did not. I bought the Mahle OEM replacement flat top pistons and they weight about the same as the stock OEM dish pistons. WS6Store sells piston sets for our engines that also do not require a rebalance. I would assume if you are replacing stock pistons with forge pistons then a rebalance would be necessary, but don’t quote me on that. I would ask Chevelle70, KCS or WS6Store, they will know.
