Are all oil galley plugs created equal?
Old May 6, 2018 | 02:46 PM
Ghost's68's Avatar
Default Are all oil galley plugs created equal?
im almost done with my LS3 swap and looking into priming my oil system. I plan on making my own setup using of those HF cordless drill pumps. But here’s my issue, due to the fact I am using Dirty Dingo sliders and the placement of the engine is in the most rearward position, I cant access my front oil galley plug that’s behind the timing cover. It’s coverea by the DD slider okate. This leaves me with the only option being the galley plug right above the oil filter.
If if I go through the rear driver side oil galley plug, will I still be able to prime the whole system including the oil pump? from what I read, that port is post pump. I installed a new oil pump as part of my build as well as many other parts.
Thanks
Old May 6, 2018 | 03:38 PM
ALL ports are post pump. The only thing on the inlet of the pump is the pickup tube itself.
Old May 6, 2018 | 04:46 PM
Ghost's68's Avatar
Lol! Didn’t even think about that. I guess ones pre and post filter? Thanks for for the clearing that up.
Old May 6, 2018 | 05:16 PM
stevieturbo's Avatar
remove plugs, spin engine on starter...primed, job done.
Old May 7, 2018 | 02:44 AM
S_M_I_D_D_Y's Avatar
Dont do what that guy said^
The starter wont spin it fast enough to make oil pressure quickly you will be spinning on unlubed bearings for quite a while. your better off just starting the thing and letting it make oil pressure in a couple of seconds IF it was assembled right with decent assembly lube
Old May 7, 2018 | 02:57 AM
If you cannot get it to prime on the starter which will easily be spinning at 200rpm or more with no load, you've fucked up when building and priming the pump.
You are absolutely not better off just starting it which would always be a last resort.
Old May 7, 2018 | 09:48 PM
Prefill your oil filter before you install it. Always.
Old May 8, 2018 | 09:27 AM
NHRATA01's Avatar
Prefilled the oil filter. Used the lawn sprayer method and put 4 quarts through the driver's side front oil galley plug behind the alternator. Pulled FP fuse and cranked the motor with the starter, had ~20psi within about 5 seconds showing on the gauge. Started up the motor for the first time and had instant pressure.
Old May 8, 2018 | 09:38 AM
Ghost's68's Avatar
thanks everyone for all the help and info.
NHRA- I was planning to do this since it seems the safest. I would hate to have issues because I decided to cut down time and just bump it over.
Old May 8, 2018 | 11:48 AM
Jimbo1367's Avatar
Be aware that oil WILL back flow thru the oilpiump. It does take a while. You will have to drain the pan a few times during the prelube session. Look for oil out of all the lifters just like a SBC. I prefer to use the port at the back of the intake. It doesn't introduce oil as bad when disconnecting when finished.
Old May 8, 2018 | 02:46 PM
NEstyle's Avatar
This was not my experience at all. I simply pushed 3-4 quarts of oil into the front galley plug until I had pressure and it was coming out all pushrods. I then added the rest of the oil and fired it up. I didn't have to drain anything.
