Piston cc of stock LS3 pistons
Just like the title says, what is the cc of stock LS3 pistons. (Not of the head chamber cc)
Also, I'm a little confused by negative/positive and dome/dish cc. I have the following SRP 298617, http://www.jepistons.com/Catalogs/SRPPRO/Chevy_SB/ls_flat_top-pro.aspx
So does dome volume -5cc mean 5cc dish Volume?
Ultimately I am trying to figure out if my compression is where it needs to be for a street car on 93 (LS3 with stock 823 heads and like .001 clean up planed on short block). I'm hoping that these pistons aren't too mild on compression and make me wish I had put something else in when I had the opportunity this past winter, since this motor already had them in it.
The cam I have is a BTR stage 4 LS3 cam, so maybe it is a good thing I have lost some static compression since my dynamic compression will be higher?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
-B
-B
