Stage 1 twin turbo cam
You might check YouTube. It surprises me which cams are found to hear there. What are the cam specs? Duration, Lift, LSA? Knowing that will give a rough idea
With about 4 degrees overlap, it will lope some, but still drive nicely.
Hi Cobra, I worked with Carrol Shelby, raced many Cobras at Willow/Riverside.
I too liked their sound especially the SC. (427)
The listed camshaft will IDLE with little "bark" as it has 2.5* overlap
My Crower LS camshaft for your needs (great sound) would be 212/219 .595"/.560" 103 C/L +2.
This is of coarse a guess as to your request for "sound" though this cam has 9.5* overlap.
This cam will Spool at 2500 RPM with Power to 6500+ RPM depending on MAP.
This is a good cam for a LOW EMAP Twin Turbo engine design.
Would you like more information ?
Lance, BTW this is the same cam spec I used in the 1st Vector Car, Twin Turbo SBC.
i'm using LJMS twin turbo stage 1 cam in my 5.3 799 heads single turbo setup with BW S475 T4 GMC Sierra. I can say that this cam is loopy but i can't say it's aggressive, drives very nicely and idle pretty good at 700 rpm.
