High compression LS3 Pistons with stock rods?
Old May 20, 2018 | 12:08 PM
Mavn's Avatar
"I MAID THEESE"
Default High compression LS3 Pistons with stock rods?
Does anyone make a shelf piston that's high comp 12.5-13.5:1? With a stock Chambered ls3 head? This would've need a +5 - +7 cc dome I think ? Nonnedd for forged rods as this is going to be straight N/A motor .
Old May 22, 2018 | 07:04 PM
Racecar2's Avatar
Off the shelf, probably not. That is a very rare configuration. I ordered a set of forged JE piston like that. With that much compression you will need to run high octane (non leaded) race fuel, or retard a lot timing to eliminate spark knock.
Buying race fuel is expensive and a pain to find. The next motor I built had forged flat tops. What a relief to pull into the gas station and say "Fill er Up".
My experience was that boosting compression was not a good way to gain power. Too difficult to find fuel. Add a little bit of camshaft, and a LS3 will be a screamer.
Old May 22, 2018 | 07:35 PM
Mavn's Avatar
"I MAID THEESE"
car will be on e85 and be solid roller. I'll just go ahead and purchase some rods 🤙🏼
Old May 22, 2018 | 08:20 PM
MIKE93SVT's Avatar
JE makes them. I'm in the exact same boat. Looking for 11.0-11.2 :1 compression out of a LS3 motor with stock rods. They're +10cc and you could run a thicker gasket to drop compression to the desired level
Only other option I'm seeing is mill the heads and cut valve reliefs in the pistons.
http://www.jepistons.com/Catalogs/Au...m_ls_dome.aspx
Old May 23, 2018 | 08:00 AM
Mavn's Avatar
"I MAID THEESE"
**** thanks bud!
Old May 23, 2018 | 10:09 AM
whatsa347's Avatar
I've been thinking about this exact same setup but its hard to find pistons to work with the stock rods, I figured for as cheap as they were some $300 dollar-ish rods would work easier. Flex fuel setup?
