Need Advice on cylinder wall damage
Old Jun 1, 2018 | 11:15 AM
btg's Avatar
btg
Default Need Advice on cylinder wall damage
Background: Spun a rod bearing in my 05 GTO while still tuning my magnacharger setup. Found a block for sale here on the forums- supposedly low mile (35K or so) with an upgraded cam, oil pump & timing chain. Mostly what I was looking for except when the block arrived I found this in one of the cylinders- looks bad enough to me that it can't be repaired or used without completely disassembling the engine. I'm no expert on LS engines but pretty good at wrenching and this damage looks bad to me- am I wrong? Seller claims the engine only sat for a few weeks with "oily rags" in the open cylinders. I don't want to go through the hassle of a return/refund through paypal if I can help it. Any advice on whether this can be salvaged without major work?
Thanks
Old Jun 1, 2018 | 10:47 PM
A.R. Shale Targa's Avatar
That’s pretty nasty. Pitting looks deep.
Need to go 1mm over bore. (.040” morning
Old Jun 2, 2018 | 01:21 AM
1FastBrick's Avatar
If that's an aluminum block, It may need to be resleeved.
Old Jun 2, 2018 | 10:25 PM
RockinWs6's Avatar
Thanks
Are you kidding? Send that junk back!
Old Jun 8, 2018 | 09:36 PM
L78steve's Avatar
A few weeks with oily rags? I don't think so. Send it back, no telling what else is bad.
Old Jun 12, 2018 | 12:10 PM
BlwnLs1GTO's Avatar
What engine is that? It's important to know this before just saying "Scrap it".
It almost looks like it's just gunk buildup. But it also looks like some pitting as well? Take some carb cleaner to it to see what it really looks like in there.
Old Jun 12, 2018 | 12:57 PM
btg's Avatar
btg
Not gunk- tried cleaners & it still looks the same,
LS2 6.0 aluminum block, supposedly low miles. Engine builder says he might be able to hone but most likely re-sleeve. I bought this block due to a spun rod bearing in my 05 GTO, by the original description I thought I could just clean it up & install my heads- I'm now having my original block & rotating assembly fixed with new bearings, rings, oil pump, timing set, etc.
Old Jun 12, 2018 | 07:26 PM
99 Black Bird T/A's Avatar
Go through the hassle of a PayPal refund. It will be less hassle and pain than using that block.
Old Oct 10, 2018 | 08:58 PM
dawgs74's Avatar
How would PayPal refund work.....would he have to pay for shipping the block back.....and who does the block get sent back too....the seller or pay pal (ebay)...
Old Oct 11, 2018 | 06:24 AM
LS2 block can go thirty over for NA but that still might not clean that one up
