Cam advice for cruiser C10 416 TVS2300 ?
Hey guys, need some cam advice for a new build I'm doing. The motor will be a 10:1 416 with stock LS3 heads, with a TVS2300 making 6-8psi and a power goal of only 550-600whp with tons of torque. The vehicle is a 4200 2wd C10 truck that won't ever see the track, only a street cruiser. Looking for something with a little idle "burble" that won't shake the truck a bunch at idle. Something like a BTR Stage 1 positive displacement cam (120 + 6 LSA), but not sure how that cam will do in a 416? The truck will have 3.42s, 28" tire, and either a GMPP 2400 stall, or a Circle D 310mm 2200 stall (haven't decided yet). As you can see from the small stall choice, the theme is mild cruiser! Oh, trans is a built 4L80e. Here is a picture of the truck:
