Should I use 799 or 317 heads for 370 N/A that will eventually see boost
So I have a 2010 GMC Sierra RCSB with the 5.3 and a D1SC procharger that ended up breaking a piston late last year. I finally ordered a new engine last month which was a 370 from Texas Speed and I was wondering what heads should I use for my application. I plan on leaving it N/A for a while til I can pay off some of the debt and have some room for potentially buying a new transmission once I add the procharger back in the mix. I have the original 799 heads off the 5.3 and an LQ4 with the 317 heads in my shed from another failed project that I could use as well. I wasn't planning on changing the heads once I add the procharger so I am guessing the 317 heads are probably the better choice but I wanted some outside input as well.
Here are the specs off the invoice from TSP:
25-Gen4IronBl - GM 6.0L Gen IV Cast-Iron
Engine Block
1ea
10-K444X3 - Wiseco Forged LS1 Piston Set:
4.030' Bore, 3.622' Stroke, 6.125' Rod
Length, 1.300' CH, -11cc Dish; Includes
Wrist Pins & GFX Steel Top/Napier Second
Ring Set
1ea
NoPRings - No Extra Piston Rings Required 1ea
46-234-5608 - ARP Main Stud Kit for
LS1/LS6-Based Engines
1ea
28-12573460 - GM LS1 Oil Restrictor
(Plastic Barbell)
1ea
28-11588949 - GM Engine Block Small
Coolant Plug, LSx-Based Engines
3ea
28-12561663 - GM LS1 Large Coolant Plug 1ea
28-9427693 - GM LS1 Oil Galley Core Plug
(Bottle Cap)
1ea
25-Mach - Full Block Work and
Preparation: Vat & Clean Block, Line Hone,
Install New Cam Bearings, Bore/Hone with
Torque Plate, Square Deck & Set Deck
Height
1ea
Labor - Labor 1ea
84-CH23 - Durabond Camshaft Bearing Set
for 04+ (Gen IV) LS Motors
1ea
28-1453658 - GM Transmission Dowel Pins 2ea
10-S718 - Wiseco Piston Wrist Pin, .927 x
2.250, .200 Wall Thickness, Straight Wall,
9310 Material, PER WRIST PIN
8ea
25-6125H - Texas Speed & Performance
6.125" H-Beam Connecting Rod, Single, No
Bolts
8ea
28-12586768 - GM 58x Tooth Reluctor
Wheel, 2006+ LS Engines
1ea
25-36222100NR - Texas Speed &
Performance 3.622" Stroke Crankshaft, No
Reluctor
Cam specs are: 227/235 .641/.649 114LSA
Was also planning on using the LS7 lifters but I have seen some mixed reviews on them. Wanted to see if they are a good choice.
And lastly any suggestions on rockers? I'm not sure if I should bother with the stock ones still or if it's worth upgrading them
Thanks in advance for any input or help!
Engine Block
1ea
Ring Set
1ea
1ea
(Plastic Barbell)
1ea
3ea
(Bottle Cap)
1ea
Height
1ea
Labor - Labor 1ea
1ea
8ea
Bolts
8ea
1ea
Reluctor
