Low oil Pressure?
Old Aug 1, 2018 | 07:05 PM
saccitycorvette's Avatar
LS1Tech Sponsor
Have you checked the pressure with a mechanical gauge?
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
Old Aug 2, 2018 | 03:40 AM
stevieturbo's Avatar
I have a mechanical gauge in the car yes....but obviously that is slow to respond vs a sensor and impossible to watch at all times. But for most part it would support what I see on the ecu ( the mechanical is actually tee'd along with the main engine sensor via the OEM location at the rear of the valley )
But 3 sensors have confirmed what is happening at various points within the oil system, so I'll need to do something at some point.
