Low oil Pressure?
20psi hot idle is fine. How about the more important high rpm psi?
Thanks
Christian
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
My 440ci big cam stroker idles at 975 rpm and hot idle is 24 psi with 50psi cruise and 90 psi at 7000 rpm.
Thank you,
Christian
Anyways, 18-25 psi hot idle is normal. 35-50 psi during rpm while hot is normal.
I removed the secondary oil pressure relief valve in the oil pan and blocked it off, replaced stock oil pump with Melling 10295 and used lower pressure spring, removed all AFM/DOD Hardware, used Sac City Corvette Billet Barbell and O-Ringed Front Oil Galley Plug, and am running at 38 psi hot idle, 50 psi at 2,200 rpm, and max out around 60 psi. Realistically, anything over 55 psi is not needed.
Thank you for your business and running our products!
I know it's said that 55-60 psi normal and that's all you need, but I just want to say that we heve a LS6 CTS-V that is a medium performance build and our C5 Z06 that is 440 ci Big Cam N/A that doe around 630rwhp. The CTS-V shifts at 6600rpm and the C5 Z shifts at 7000rpm.
We have been running both of these engines with higher oil pressure for our test purposes and when we tear these engines down the rod and main bearing look much newer and less wear than the engines running the 55-60 psi.
Just our opinion, but we prefer the higher pressure even though it cost a little hp. We feel it keeps the hydraulic lifters pumped up better at higher rpm and floats the bearings better so they don't touch the crank. 55psi doesn't even meet the so called 10 psi for every 1000 rpm.
Just our opinion and what we see when we open the engines. That is how we test our Oil System Improvement Products.
Thanks
Christian
As far as AFM/DOD I have a Diablo tuner and just recently disabled it with it.
Thanks
Christian
Do you still recommend 60+ Psi on stock builds, or H/C/I builds under 6,500 rpm?
And as long as you have a hot idle of around 25 you should be good to go. I hear a lot of people talking about how good their hot idle psi is, but its most important to check hot high rpm psi. I don't hear much talk about that.
Remember GM designers run the lower psi to help with fuel economy and that is just enough oil psi to get by.
Thanks
Christian
6psi @ 1000rpm
18psi @ 2000rpm
24psi @ 4000rpm
Sounds pretty damn low ! even more so when they list a stronger oil filter to handle higher pressures and they say the oil squirters have check valves that dont open til around 43.5psi.
So presumably these engines do make considerable more than their minimums
I know my LS2 with oil squirters rarely makes over 50psi when hot ! and it freaks me out. Tried both the 296 and 355 pumps, if anything the 296 was a little better. Shimming the 355 almost seemed to make it a little worse.
Baffling, unless those squirters dump some serious oil.
6psi @ 1000rpm
18psi @ 2000rpm
24psi @ 4000rpm
https://www.enginelabs.com/engine-te...s-race-engine/
Many other engines do operate at various ranges of pressure...ultimately as long there is sufficient oil flow to everything, pressure is slightly less important, as it isnt pressure that creates the barrier between metal parts, it's the oil composition itself.
That said...I'd love to know why the **** my oil pressure is *****.
I've tested before my filter, directly after my filter and also in the normal main gallery spot.
And at higher rpm I'm losing around 15-20psi between that first and last point. Although I also have oil squirters which I'm sure drain a lot of oil....although the LS9 data says they do not open til 43.5psi. ( which perhaps coincidentally my OP rarely goes above when measured at the engine )
But pre-filter I do see around 65psi. remote filter, large -12 lines. Tested with 3 different filters with little change. That's the Melling 355 pump with the relief shimmed a little.
It was a nightmare! Went through a couple pumps, shimming them, then went from an-10 to an-12 lines to the remote filters and on and on. Turns out it was warn out cam bearings!
How new are your cam bearings?
Thanks
Christian
Although the only caveat was it was sourced via AES...so **** knows. The block certainly was brand new....and it didnt look like anyone else had installed the cam bearings, so I presume they were just GM installed.
They installed the squirters for me and billet/pinned main caps. I installed all caps/plugs on the brand new block ( it came without any, so in that respect I know it was new )
I also try and smooth the corners of the internal oilways where possible which was easier with no plugs installed.
I also pinned the cam bearings as I've had issue there before so I know they havent walked. I've tried various oils from as low as 5/40 to my current 10/60 and TBH they all made no real difference.
When cold it will make the sort of pressure I'd like though
It runs fine, even my old bearings I removed when it was apart doing other stuff last 2 times were fine although this time I did go to ACL from King just to try a change....so as much as it isnt good...it also doesnt appear to be a real problem at the minute. But it certainly is not how I want it to be.
Nothing bad to say about either brand as I've used both successfully over the years.
I'll maybe take a look at it more seriously over the winter and consider a different oil pan ( currently Autokraft I've been using for last 10 years or so ) and going back to the 296 but heavily shimming it or a much stronger spring
Oddly it did seem to make a little more pressure with the 296 ! and was a little more stable. But a small amount
But with 3 sets of bearings, 2 King and 1 ACL, 2 pumps, 296 and 355 ( and then 355 shimmed slightly )....I really doubt main/rod bearing clearance is an issue...except perhaps cam bearings as mentioned.
But something is not as happy as I'd like it to be. As said...it isnt an actual problem, it all runs fine etc...but via logging I know the oil pressure is not where it should be.
But of more interest...why the huge losses/pressure drop from filter inlet to engine main gallery !
Even the 8psi or so at higher rpm's across the filter seemed huge to me. And that is literally with a sensor either side of the remote filter housing, not even a few inches of hose too.
