Summit Pro LS Cams
To put it simply. The bottom end and RPM range determines how much air the engine wants. The heads will determine how fast you can fill the cylinder. Based on that you can determine how long to open the valves. If you don't open the valve long enough, you don't build as much cylinder pressure as you could. Hold it open too long, and you bleed off cylinder pressure. A better flowing set of heads on the same bottom end will need a smaller camshaft to optimize cylinder pressure.
Edit: I misread what he said, but i'm gonna leave it.
He isn't saying that there is a single cam out there that works for everything. He's saying that for everything, there is already a cam out there somewhere that works.
I still do not wholly agree. I've seen cams from the big names out there get replaced with a proper custom and make a big difference. Maybe they picked the wrong camshaft at the start, but someone who understands the math behind this stuff can definitely get more than 1% improvement.
Ask anyone I'm messing with are those pie in the sky post = numbers, and facts lil buddy. Dude your 700 hp 11 second or your old 10.6@132 pass says it all. I don't F with Slow people. You need to ask someone?
If it doesn't do what I'm asking I'll burn it! Not part it out....Burn it!
Comp 13065/13068-113 is a 259/271 .720/.720 113 LSA hydraulic roller.
Comp 14346/14350-113 is a 260/268 .739/.739 113 LSA hydraulic roller.
Comp 12106/12112-113 is a 261/273 .715/.715 113 LSA hydraulic roller.
Comp 12636/12136-113 is a 259/271 .715/.715 113 LSA hydraulic roller.
When used with 1.7 rockers:
Comp 13988/13994-113 is a 259/271 .755/.755 113 LSA hydraulic roller.
If you want, I can go through their solid rollers just to show you how still not special your custom cam is.
And I still haven't checked any other manufacturers yet.
All of these will make within 1-2% power of your 'custom' cam.
Match it cam matcher. Hell a blind man can go look thru Comp master lobe and match or copy a lobe.......Match something with no specs. Just power band and peak and get within 1% 4 inch crank .030 over . I have the specs. BTW 1.8 rockers. Your no cam maker but can copy to match a cam. Nothing to copy this time.
You're not proving anything here. You are rambling and making yourself look bad.
