5.3 crank in 6.0?
5.3 crank in 6.0?
I have a 6.0 gen 4 with a bent crank snout, I have another good gen 4 5.3 crank. I am hoping to use the 5.3 crank in the 6.0 engine but I have been reading that the balance is different. I looked up some part numbers for reman crankshafts at rock auto. Both engines pop up as the exact same part number for reman cranks? So would the assembly need to be balanced or are they the exact same? Thanks
Send a message to KCS
Moderator
how about from a 6.0 to a 6.2l? I'm not sure if my crank was from a 6.0, or a 6.2, however, it did have a throw out bearing in it with a 58x reluctor, which tells me either ls2 crank or ls3. However I did not balance it for ls3 flat top pistons. Will I be okay?
