6.0l ls
Old Aug 23, 2018 | 09:25 AM
raszamataz46's Avatar
Cool 6.0l ls
need help if any one can inform me have 6.0l 1721 cam all my rockers adjusted to 1 and 3 quarter turns would have liked 1 /1/2 turns but besides the point, 3 intake and 4 intake i only got 1/4 turn b4 tight, this was after all lash taken out by the way. why is 3 and 4 intake only giving me 1/4 turn i know i can fix this with different size push rods but just dont understand why these two valves only giving me 1/4 turn this cam supposed to be 5.3 ho ,327 delux 196/201.467 116 lsa any help with what my problem is {1721} cam.
Old Aug 23, 2018 | 03:27 PM
KCS's Avatar
KCS
Moderator
Are the lifers all on the base circle when you tighten the bolts down?
Old Aug 23, 2018 | 08:52 PM
yes all on base
Old Aug 23, 2018 | 08:55 PM
Lightbulb
checked and rechecked and why only three and four intake vlaves all the rest did as they were supposed to do adjusted i mean.
Old Aug 24, 2018 | 12:26 PM
BlwnLs1GTO's Avatar
Tell us about the heads.
Are they untouched take offs? Have they EVER been worked or at a machine shop? Take a straight edge and lay it over the top of the valve tips. How do they look? Do that on each head and report back.
As these engines get older, more and more people are putting their hands on them freshening them up, valve jobs, porting etc...It's always best to measure each and every valve. Tedious, yes, worth it? IMO Absolutley
unless it was a bone stock untouched engine freshening.
I had a set of heads that were CNC ported in 2009 by somebody, purchased from a shop along with a built LS2 stroker short block. I found that the Intake valves were about .030" "Taller" than the exhaust on every valve.
I purchased 2 sets of Push Rods to meet my desired preload on LS7 lifters. You'll likely have to do the same unless some of them are way out of spec... Good luck.
