Having low oil pressure after AFM delete in a 5.3 LH6.
#41
LS1Tech Sponsor
Received 1,190 Likes
The following 2 users liked this post by Summitracing:
ezstriper (06-25-2019), RookieLSer (04-09-2021)
The following users liked this post:
#43
I did the DOD delete a few months ago, new oil pump, plugged DOD relief valve, new lifters, delete solenoids, TSP cam installed. Ran great. Mileage suffered. Oil pressure was great.
Today I installed GM 12689035 camshaft. Recommended by Texas Speed as a stock alternative to the DOD factory cam. Fired it up and oil pressure is down. 12 psi at hot idle. According to the manuals it there, this is still above minimums. Strange that it dropped though. Anyone have ideas?
#44
#46
I inspected before installation and the retainer plate looked great. I even inspected the seal. The pressure was good before the cam swap. The only difference in the cam was the new one has a groove machined in #2 journal, I think for VVT. Many are using the same cam for DOD delete. Thanks for the input. I'm wanting to try to figure it out before I disassemble again.
#48
Would it be possible to reuse the cam retainer plate if you resealed it with anaerobic sealant? Because that's what I did on my build...
LS CHEVY II (12-19-2020)
#50
LS1Tech Sponsor
#53
I disassembled everything, measured cam bearing sizes, inspected everything I could. Installed new cam retainer plate. Again, low oil pressure. I checked with a manual gauge also and it confirmed what the computer says, 12 psi hot idle. I'm thinking that the relief valve in the oil pump may not be seated closed allowing oil to blead by the relief. Anyone have other ideas? Thoughts?
#59
What doesn't make sense is that oil pressure was fine with the mentioned changes until I swapped the cam. If you scroll up on the thread you can see my original post, it should have all the details. I appreciate the input. I just did some research and there are 2 different o-rings for the oil pickup tube depending on application. I did not know this at the time I changed the oil pump. ?????
