Trickflow 228 230 for ly6
https://www.google.ca/amp/s/www.hotr...-end-loss/amp/
Now...what do you refer to as “ok idle”? Everyone perceives this differently.
So the 6.0’you did doesn’t feel doggy down low even with rec port heads and that cam? Thanks
I put together a 10:1 5.3liter, 243 heads, with a 228 Texas Speed camshaft for him (nephew) the first go around, and this engine is night and day stronger. While street tuning, it pulled out to over 7k rpm, and the tuner couldn’t believe it. It’s quick.
I can’t say I really have a major goal as far as power goes but it would be nice if it was around the 400whp mark. I always read these magazine articles and they always manage to hit astronomical numbers. My biggest concern is having a strong broad range of power and good street manners. I might also mill the heads .020”
The LY6 already has great heads (same as LS3), so all you really need is a good cam. And if you like a little lope and great response all the way up and down, use the High Lift Hot cam from WS6store. This cam in an LS3 puts out north of 500HP flywheel. A little less in a 6.0 LY6, so I think you can realize your goal in a very strong combo like this.
Through shorty-ish headers, mild ported heads and a 2 1/2" exhaust, I laid down 458hp/408tq at the wheels. Torque throughout the RPM curve is more than adequate in getting this 4400LB beast movin'!!
This is my daily driver and at 58yoa, I'm not gonna be dealing with a whole lot of 'craziness' with this car. Jus' sayin'.
KW
