Check out the NEWEST Summit Pro LS Cams
Old Dec 7, 2024 | 11:53 AM
  #381
Project GatTagO's Avatar
Originally Posted by Austinbelair
Would the 8719 cam be good for a 2014 Tahoe with 150K miles on the 5.3? I want to AFM/VVT delete it. I'd prefer to not use a bigger stall in the 6L80E if I can avoid it. Mostly street driving, beach runs and getting groceries in it.
That cam will work great, especially with a stock converter.
Andrew
Old Dec 10, 2024 | 10:26 AM
  #382
Summitracing's Avatar
LS1Tech Sponsor
The SUM-8719R1 cam is a great choice for your 2014 Tahoe with 150K miles, especially since it avoids needing a bigger stall in the 6L80E. Its -7° IVO (intake valve opening) also provides a smooth to noticeable idle, ideal for street driving, beach runs, and errands. Pair it with LS6-style beehives and it'll be happy out to 6,500.
@Abs suggested the SUM-8728R1 as an option which we would consider as well. It’s slightly larger, providing more power and torque across the board, and still works with a stock converter. However, it's -1° IVO means the idle won’t be as smooth as the 8719R1. You’d also need to upgrade to .600" lift beehives, but since you’re already upgrading, it could be worth it.
If you value a smooth idle, go with the 8719R1. If you want more performance and don’t mind a slightly rougher idle, the 8728R1 could be the better choice.
AFM and VVT would need deleting for either of these cams. Your engine might have one or both systems depending on its VIN or RPO code. If you're absolutely sure you need to delete both, you're good to go. If not, you can confirm using our LS RPO Code Database with the 8th digit of your VIN or your RPO code. Once you're ready, we offer delete kits from a variety of trusted vendors to help you get the job done.
- AFM/DOD delete kits
- VVT delete kits
Let us know if we can be of any further assistance. We'll be happy to help!
__________________
800-230-3030
www.SummitRacing.com
Old Feb 13, 2025 | 01:05 PM
  #383
Kfxguy's Avatar
Why are the SUM-8712 and 8718 no longer available?
Old Feb 13, 2025 | 01:10 PM
  #384
SUM-8712r1
Old Feb 13, 2025 | 02:01 PM
  #385
LS1Tech Sponsor
Hey ​​​​@Kfxguy,
We haven’t seen you around in a bit—nice to see you back!
Back around 2021, most of the standard Pro LS Cam part numbers were discontinued. The R1 was added to the end of the number to mark the updated versions.
We worked closely with our lobe designer and found small but effective tweaks. While we can't share the proprietary details, these changes made our cams even easier on the valvetrain than they already were and extended the RPM range slightly.
Let us know if you have any questions!
__________________
800-230-3030
Old Feb 13, 2025 | 02:15 PM
  #386
Abs's Avatar
Abs
Originally Posted by Summitracing
Hey ​​​​@Kfxguy,
do you have an update on the new single plane cams?
Will any be smaller with intake durations in the 21X or 22X where piston valve reliefs wont need to be cut?
Old Feb 14, 2025 | 11:46 PM
  #387
Kfxguy's Avatar
Hey ​​​​@Kfxguy,
I’ve been popping in and out here and there on the website, mainly in the trans section.
I’ve been perusing the summit website considering selling my spare motor to build a destroked ls2 or ls3 and putting my built 5.3 on the stand as a spare. That motor is still holding up. It’s been put through its paces for sure. I think it has around 40k miles on it now. It’s seen 20+psi boost countless times. I’ve driven it daily off an on for the past few years. Only issue I had was right after getting it together I cheaped out on valves and put some $50 junks in there instead of ferrea and I tuliped one. Ferreas went in and I haven’t had an issue since. Still have the same spark plugs. This is the pro ls bottom end engine that you guys helped me out on, still running the ghost cam too. After pricing stuff out, I’m probably gonna hold off on building another engine. I do have a set of pro ls pistons for my 5.7, all I need is rods and I could put that motor together.
thanks for the heads up on the cam part numbers. I’m gonna pick one out for my son’s truck and do a mild one while the truck is apart. Thx
Old Feb 17, 2025 | 10:26 AM
  #388
LS1Tech Sponsor
Sounds like that Pro LS bottom end has really proven itself! 40K miles with 20+ psi is no joke—that's awesome to hear it’s still holding strong. Cool to hear that you're still running the Ghost cam. That's such a great cam for a variety of applications. Definitely a good call on upgrading to the Ferrea valves. Sometimes those early lessons pay off in the long run!
If you do decide to move forward with the destroked LS2/LS3 build down the road, we’d love to help you spec out the right combo. And it sounds like you’re already close to having everything you need for the 5.7—just a set of rods away!
That’s awesome that your son’s getting a mild cam setup while the truck’s apart. Let us know what kind of goals you have for it, and we’d be happy to help make sure he gets the best option for what he’s after.
Appreciate you checking in, and as always, let us know if we can help with anything!
__________________
800-230-3030
Old Feb 17, 2025 | 11:06 AM
  #389
LS1Tech Sponsor
We don’t have any updates to share on new Single Plane cams just yet, but as soon as we do, we’ll be sure to post right here on LS1Tech.
__________________
800-230-3030
