Upgrade the LY6, start with an LS3 or save for a LS7?
The dynamic compression ratio of the stock LY6 because of the dished pistons will not be optimal with a cam profile required for 525RWHP
LY6 will require a significant bump in compression in order to make up for the cubes
Edit: If he wanted to do a budget build he could machine it for LS3 pistons.
My 408 was quite a bit of work, Bored/decked/Line Honed/new crank/rods/pistons/CNC porting of the AFR heads and so on.
