Upgrade the LY6, start with an LS3 or save for a LS7?
I would love to have about 525-550rwhp once it's all said and done, but I don't know enough about LS motors to decide if I should keep the LY6 and build it up, purchase a GM connect and cruise LS3 and upgrade the cam, or save a little more and go with a GM connect and cruise LS7. Preferably, I'd like a high revving NA motor on this build.
The LY6 is connected to the old stock Muncie 4spd so that has to go. My budget is around $15k which needs to include a new 6spd Tremec. What do you guys think is my best option motor wise?
As far as dependability, it seems to be doing OK, though there have been some cases of it failing in a performance build.
I haven’t seen any issues other than someone not using a cam phaser in their build, and it bit them.
It's going to get a full Speedtech Performance upgrade so I'm definitely not going to skimp on the chassis department.
If you're going to do track days for fun then the iron block will be fine, If you really want to get serious about it then the aluminum block is the only way to go. Any weight you can shed from the nose will make the car handle and brake better. Your HP goals aren't going to be hard to reach either way.
Setrab Cooler. (These are plate style, high flow and very good quality, no they are not china cheap.. )
Mocal oil thermostat. (you can overcool engine oil, it needs to get above 170 to keep most of the moisture evaporated out)
Thermostat allows running a large cooler without overcooling gives more capacity and headroom for the really hot days.
Size the hoses to match the actual flow, don't go bigger is better. (It isn't always)
Some good hydraulic shops have sizing tables of flow-rate/pressure and hose size and length.
-8 depending on the engine with a stock pump is usually plenty. You roil pressure should be close to the same
before and after you install the cooler..
DON'T USE PUSHFIT STYLE HOSE. use braided with Aeroquipe style fittings, they don't pop off..
I've towed too many car-b-ques off track that used push fit style for pressurized oil.
Accusump with either manual valve OR Electrical valve activated by low pressure switch,
Do not turn on electrical to the Accusump valve and leave it on it will overheat and quit,
their valve is a one way valve that can open for 2 way.. Many people wire them up with a toggle switch
rather than wire the pressure switch in.. Then forget to turn the switch off in the pits and fry the solenoid.
Accusump with manual valve OR Electrical valve activated by low pressure,
DO not turn on electrical to the Accusump valve and leave it on it will overheat and quit.
Have a TON of fun with this! I know I would!
Best option? Imo stick with the VVT and get a custom grind cam and matched springs. See if you can get hold of Geoff Skinner at EPS, listen carefully to his advice. Ed Curtis as well specs cams for such purposes. Thats about all I would do to an LY6 and if you want more than that brings ya build a new motor. Add more cubes for 525+whp
