Cathedral vs Ls3 test
I've just never been impressed by them. I think people short the 243s and move on to easily myself. Ima fan of using production heads mostly. But i made 451whp with stock 243s and a stock cam.....so what to i know.
for a truck yea .....for a hotrod not at all. They don't call them tq ports for nuffin. Although i do appreciate good broad power i personally would never cam or h/c a ls for a hotrod and mind losing some low end (call it below 4k rpm) for the massive gain in topend power the ls3's offer. When it's all said and done with being able to pull more gear with the ls3 heads due to the rpm advantage there will be no real world low end loss.
Why do you need an extra 10 ft\lbs of torque at 2500 rpm for idling around in a 3500 lb car? The extra power is actually more usable up top because you’re just not using it down low
Yah I mean the valve train is definitely an issue out of the box but a set of BTR springs and titanium retainers with turned down ls3 valves can change that.
“While not identical, the camshafts are very, very similar. Really, there were as many similarities as was possible.”
THIS TEST IS CRAP! Why?
we all know good and damn well two different engines will make different power. What about bearing clearances? Do you guys think that all the bearing clearances are exactly the same? No. What about friction in each motor? What about piston ring gaps? Piston ring seal? spark plugs? gap? Done on two different days also. I mean really? this is a bogus, waste of time test. We all know the LS3 heads are superior anyways....but just swap heads on the same motor in the same day to see the real difference. It could be less or even more. SMH
