Cathedral vs Ls3 test
From the context of the article it appears the engines are NA. Who builds 427's NA 9.8:1 static compression ratios unless the engines are intended for forced induction later.
Someone must be wanting to run some cheap 87 Octane gas in their 427.
Would also like to see the details from 2,500 rpm to 5,000 rpm.
Also, that power past peak is tremendous. You gain so much more actual torque at the tires by staying in the lower gear and riding that power curve down. I got one am glad to see someone finally spun the motor instead of letting up right when it peaked.
And it highlights what the rectangle guys have been saying -- you need rpm to take advantage of the rectangle ports. If you are not going to rev there is not much advantage if any.
Wonder how many poor performing ls3 Head combos are poorly driven...
Even on street, not unusual for me to hit 7400 clowning around.
If the test compared similar cathedral and rectangle port heads (CC, valve size, camber volume, and flow figures) without altering the valve events and top end - the results would be far more legitimate and telling. The problem is that focused empirical testing doesn't make for copious internetz clicks, and sure doesn't impress half-wit readers bench racing in their trailer parks. That and most "journalists" lack the capacity to objectively visit any topic as investigative journalism is a lost art - the highest volume of bullshit out the door wins.
So this is the crap we get.
I wouldn't run a cam spec'd for cathedrals on an LS3 headed setup and vise versa.
Like everyone else that compression ratio for N/A just sucks.
I'd like a little more detailed test with full specs of the heads valve sizes, chamber volume, intake volume etc....
Seeing those "dips" in the torque curve at similar point of both engines, I'd suspect it was the induction side of the engine, most likely the Holley Hi-Ram.
Address that issue, and I bet you find more power and a much better running combination.
But, hey... if you want to change my mind be my guest and get typing.
It's not just that either. MH Mike post was good. This is nonsense.
